Dual WAN on AC66U using Huawei E97 - T-Mo
StuartGrant
First post here. I had a dual-WAN setup over the summer using a $5 T-Mobile Jet Connect 2G/3G Dongle. T-Mobile changed the radios on their tower near me to LTE in September 2015 and the Jet could only connect at 2G 12kbs speeds. So I bought a Jet 2 for $25 hoping the newer version would work with 4G. Nope. So I just got a Huawei E397 for about $55. It connects perfectly at 30Mbs LTE attached directly to my PC but is not able to connect when attached to the USB port of the Asus RT-AC66U. Router firmware is stock, updated to the latest.
I know that this 4G device is not officially supported by the Asus but hope someone may have some hints. Let me repeat that I can connect perfectly attached to the PC and using the same APN settings doesn't work with the router. I like the Asus a lot and I am using the AICloud and Asus DNS but will get a different router if needed to get Dual WAN working with 4G. ... Thanks
