Dynamic DNS No Longer Working?
jhoff80
As of a couple of days ago, Dynamic DNS is no longer working for me on a RT-AC66U running the latest Merlin build. Nothing has changed in the past week at all other than this not working.
My provider is Namecheap, and when trying to use that:
Apr 12 14:01:21 ddns update: ez-ipupdate: starting...
Apr 12 14:01:21 ddns update: connected to dynamicdns.park-your-domain.com (199.188.202.39) on port 80.
Apr 12 14:01:21 ddns update: unknown return code: 400
Apr 12 14:01:21 ddns update: server response: Bad Request
Apr 12 14:01:21 ddns update: asusddns_update: 1
After trying to switch to DNSomatic, using the setting of all.dnsomatic.com as hostname like all guides say to:
Apr 12 14:01:51 ddns update: ez-ipupdate: starting...
Apr 12 14:01:51 ddns update: connected to updates.dnsomatic.com (67.215.92.215) on port 80.
Apr 12 14:01:51 ddns update: invalid hostname: all.dnsomatic.com
Apr 12 14:01:51 ddns update: asusddns_update: 2
Anyone else seeing this? Is it just me?
Zoneedit is also down
Ironically, I'm having a similar problem with Zoneedit, but it appears that the site "dynamic.zoneedit.com" is down.
Apr 12 19:51:57 rc_service: httpd 374:notify_rc restart_ddns
Apr 12 19:51:57 ddns: clear ddns cache file for server/hostname change
Apr 12 19:51:57 ddns update: ez-ipupdate: starting...
Apr 12 19:51:57 ddns update: connected to dynamic.zoneedit.com (64.85.73.112) on port 80.
Apr 12 19:51:57 ddns update: error recv()ing reply: Connection reset by peer
Apr 12 19:51:57 ddns update: strange server response, are you connecting to the right server?
Apr 12 19:51:57 ddns update: asusddns_update: 1
Apr 12 19:52:09 rc_service: httpd 374:notify_rc restart_ddns
Are you sure Ez-ipupdate is working alright?
My ddclient is working well with DnsOMatic right now.
Fixed it
Well, I switched from zoneedit to namecheap and all is well.
Apr 12 22:18:14 rc_service: httpd 374:notify_rc restart_ddns
Apr 12 22:18:14 ddns: clear ddns cache file for server/hostname change
Apr 12 22:18:14 ddns update: ez-ipupdate: starting...
Apr 12 22:18:14 ddns update: connected to dynamicdns.park-your-domain.com (199.188.202.39) on port 80.
Apr 12 22:18:14 ddns update: request successful
Apr 12 22:18:14 ddns update: asusddns_update: 0
Apr 12 22:18:14 ddns: ddns update ok
Hi guys,
I'm having issues getting Namecheap to work as well.
I'm using my main domain name as the dynamic name. So not a sub-domain.
On my WHS box, I can successfully update using the program namecheapDDNS Client. It has @ as the host and the domain name setup along with the password.
If I try the same variables in the Merin build, it keeps giving me error msg: "Request error! Please try again"
Here's what shows up in the logs:
Apr 29 21:36:07 watchdog: start ddns.
Apr 29 21:36:07 rc_service: watchdog 308:notify_rc start_ddns
Apr 29 21:36:07 ddns update: ez-ipupdate: starting...
Apr 29 21:36:07 ddns update: connected to dynamicdns.park-your-domain.com (199.188.202.39) on port 80.
Apr 29 21:36:07 ddns update: error processing request
Apr 29 21:36:07 ddns update: server output: HTTP/1.1 200 OK^M Cache-Control: private^M Content-Length: 417^M Content-Type: text/html^M Server: Microsoft-IIS/7.5^M Set-Cookie: ASPSESSIONIDSCQTQRAC=HJNAOPAAGLDPPABOLCOOMJEK; path=/^M X-Frame-Options: SAMEORIGIN^M Date: Wed, 30 Apr 2014 01:36:07 GMT^M Connection: close^M ^M <?xml version="1.0"?><interface-response><Command>SETDNSHOST</Command><Language>eng</Language><ErrCount>1</ErrCount><errors><Err1>Passwords do not match</Err1></errors><ResponseCount>1</ResponseCo
Apr 29 21:36:07 ddns update: asusddns_update: 1
Any idea why this isn't working?
I'm running 374.41
Thanks in advance!
I'm using Namecheap as well and have no issue. In the error you provided it's says that the password entered doesn't match. Could it be that you've got an extra character being sent? The first time I copied and pasted the password in I had a extra space that was pasted in.
Hi guys,
I'm running 374.41
Thanks in advance!
