Entware + libpcre.so.0 error
WaVeR
Hi Folks,
I tried to upgrade some Entware packages and had an error
# opkg update
Downloading http://entware.wl500g.info/binaries/entware/Packages.gz.
Inflating http://entware.wl500g.info/binaries/entware/Packages.gz.
Updated list of available packages in /opt/var/opkg-lists/openwrt.
# opkg upgrade
Upgrading ldconfig on root from 0.9.32-7 to 0.9.32-8...
Downloading http://entware.wl500g.info/binaries/entware/ldconfig_0.9.32-8_entware.ipk.
Upgrading libc on root from 0.9.32-7 to 0.9.32-8...
Downloading http://entware.wl500g.info/binaries/entware/libc_0.9.32-8_entware.ipk.
Upgrading libpthread on root from 0.9.32-7 to 0.9.32-8...
Downloading http://entware.wl500g.info/binaries/entware/libpthread_0.9.32-8_entware.ipk.
Upgrading bash on root from 4.2-3 to 4.3.30-1...
Downloading http://entware.wl500g.info/binaries/entware/bash_4.3.30-1_entware.ipk.
Upgrading libpcre on root from 8.11-2 to 8.35-3...
Downloading http://entware.wl500g.info/binaries/entware/libpcre_8.35-3_entware.ipk.
Removing obsolete file /opt/lib/libpcre.so.0.
Removing obsolete file /opt/lib/libpcre.so.0.0.1.
Removing obsolete file /opt/lib/libpcreposix.so.0.0.0.
Upgrading libstdcpp on root from 4.6.4-7 to 4.6.4-8...
Downloading http://entware.wl500g.info/binaries/entware/libstdcpp_4.6.4-8_entware.ipk.
wget: can't load library 'libpcre.so.0'
Upgrading mtr on root from 0.82-1 to 0.85-1...
Downloading http://entware.wl500g.info/binaries/entware/mtr_0.85-1_entware.ipk.
Upgrading libgcc on root from 4.6.4-7 to 4.6.4-8...
Downloading http://entware.wl500g.info/binaries/entware/libgcc_4.6.4-8_entware.ipk.
Upgrading librt on root from 0.9.32-7 to 0.9.32-8...
Downloading http://entware.wl500g.info/binaries/entware/librt_0.9.32-8_entware.ipk.
Upgrading libopenssl on root from 1.0.1g-1 to 1.0.1i-1...
Downloading http://entware.wl500g.info/binaries/entware/libopenssl_1.0.1i-1_entware.ipk.
Configuring libc.
Configuring ldconfig.
Configuring libpcre.
Configuring libpthread.
Configuring bash.
Collected errors:
* opkg_download: Failed to download http://entware.wl500g.info/binaries/entware/libstdcpp_4.6.4-8_entware.ipk, wget returned 16.
* opkg_install_pkg: Failed to download libstdcpp. Perhaps you need to run 'opkg update'?
* opkg_download: Failed to download http://entware.wl500g.info/binaries/entware/mtr_0.85-1_entware.ipk, wget returned 16.
* opkg_install_pkg: Failed to download mtr. Perhaps you need to run 'opkg update'?
* opkg_download: Failed to download http://entware.wl500g.info/binaries/entware/libgcc_4.6.4-8_entware.ipk, wget returned 16.
* opkg_install_pkg: Failed to download libgcc. Perhaps you need to run 'opkg update'?
* opkg_download: Failed to download http://entware.wl500g.info/binaries/entware/librt_0.9.32-8_entware.ipk, wget returned 16.
* opkg_install_pkg: Failed to download librt. Perhaps you need to run 'opkg update'?
* opkg_download: Failed to download http://entware.wl500g.info/binaries/entware/libopenssl_1.0.1i-1_entware.ipk, wget returned 16.
* opkg_install_pkg: Failed to download libopenssl. Perhaps you need to run 'opkg update'?
# opkg update
Collected errors:
* opkg_download: Failed to download http://entware.wl500g.info/binaries/entware/Packages.gz, wget returned 16.
# opkg update
Collected errors:
Any idea how to solve this issue?
I don't know if it's the correct way but to fix the issue I created a symlink for libpcre.so.0:
cd /opt/lib
ln -s libpcre.so.1 libpcre.so.0
and retry to update/upgrade
# opkg update
# opkg upgrade
Configuring libgcc.
Configuring libopenssl.
Configuring librt.
Configuring libstdcpp.
Configuring mtr.
Thanks ryzhov_al
I reinstalled 'wget' and removed the symlinc that I created.
Regards,
