entware/optware aircrack-ng
vehmaki
I have asus rt-n66u running asuswrt.
I have installed aircrack-ng package, but it wont start due to missing package Wireless tools.
So my question is can anyone compile this package and add it to repository.
Pardon?
# opkg depends aircrack-ng
aircrack-ng depends on:
        libc
        libpthread
        libopenssl
        libpcap
What is Wireless tools package?
Pardon?
        libc
        libpthread
        libopenssl
        libpcap
Sorry I meant when I start airodump-ng which is part of airocrack-ng I get error:Wireless tools not found
Ah! Now I get it. While starting, any airocrack* tool searches for some standard linux utilities which absent in our small embedded device. Here is workaround:
opkg install coreutils-true
ln -s /bin/echo  /opt/bin/iwconfig
ln -s /bin/echo  /opt/bin/iwpriv
I did all of above but still get same error wireless tools not found
Should I restart router after running above commands?
No, it's not necessary. I've checked on Entware installation.
Airodump-ng needs wireless tools. Can you get your interface in monitor mode with airmon-ng without wireless tools? Otherwise I like to know.
Look at this thread https://forum.openwrt.org/viewtopic.php?pid=193869#p193869
I cannot install this package => http://backfire.openwrt.org/10.03/brcm47xx/packages/wireless-tools_29-4_brcm47xx.ipk due incompability with architecture.
Is it possible to get this package to the entware repo?
I have compiled it http://www.sendspace.com/file/69y2nz
Now aircrack-ng tools like aireplay-ng, airodump-ng are displayed properly.
Wireless-tools is hardware depended package.
It is true but could you please help me to compile the rtl8187 modules?
I'm using a awus036 usb wifi adapter and it seems to work nicely on open wrt.
I have tried to compile the modules but the ieee80211 stack seems to be broken.
Would you please take a look to see what's wrong with makefile
http://www.sendspace.com/file/lkz450
