Error 404 when using router's UI
Miguel Santa
I have been getting this 404 error when I click on any section of the UI on my RT AC5300 and the following message:
"Settings have been updated. Web page will now refresh.
Changes have been made to the IP address or port number. You will now be disconnected from RT-AC5300.
To access the settings of RT-AC5300, reconnect to the wireless network and use the updated IP address and port number."
Occasionally the WAN ip changes when this happens, I have no idea what's causing this error. Does anyone know how to fix this issue or is experiencing the same thing?
Clear your browser cache or use Private/Incognito Mode (which does not use cached data).
Thanks for the tip, so far it's been fine, I guess that did the trick for now. I'll let you know otherwise. Thanks a million!
Often happens when you replace old router in use with new one.
