Does anyone know if this update addresses the CVE-2023-39780 SSH exploit? I figure it does, usually Merlins stuff is ahead of the game. Just wanted to ask specifically since I did not see it addressed in the changelog.
Old CVE from 2023. Discussion about it here: https://www.snbforums.com/threads/g...gn-affecting-thousands-of-asus-routers.94809/
This article is about the malware itself, not about a new security issue. That malware is getting installed through brute forcing of the login, or through old security issues (one of them going back to 2023 - long fixed).
I assumed as much, like I said every time I ask which is infrequent, your firmware is well ahead. Thanks for taking the time to link as well.
@RMerlin 's firmware is well ahead. I take zero credit except for finding the link :D
The Google DNS may be hard coded into the FireTV. If so you may need to block the Google DNS using the LAN > Router page in the GUI. Example (the Gateway IP address is the router's address):
I'm sorry, it's a newbie question, why set your metric to two? Wouldn't leaving it blank or setting it to zero zero be more preferable?
In case it's of interest, I picked up a shiny new RT-BE92U on Wednesday, immediately put this Merlin release on it and painstakingly set up all my personalization. The only "custom" scripts was a firewall-start that is admittedly a bit on the large side. None of the extra bits were turned on (except I played with SNMP for a while; and gave up).
I experienced multiple crashes over the two days. Sometimes it'd presumably try to restart and simply not, so I'd see the power light on and nothing else (no networking running at all). A power-cycle would bring it back ... for a while.
Tried a factory reset with Merlin and re-entered the minimalist personalization, and still it crashed.
Finally, I factory reset again and put on the latest stock Asus firmware. No crashes so far (6+ hours). I was considering I got bad hardware, but it's looking like not.
I am aware that the "stock" firmware is a later GPL than Merlin. I do have some logs from overnight last night, which has an awful lot of weird stuff in it.
Current plan is to stay "stock" <yech> for now, and when the next Merlin comes out, presumably based on the newer GPL, try again.
In the meantime, if there's any desire to look at what I have for logs in case there's a clue, I'll keep them handy.
Brad.
Did you follow the Asus-Merlin 3006 change log directions to enable the downgrade capabilities when flashing on top of Asus stock firmware 3006.102_37000 or greater?
- NOTE: If flashing on top of Asus stock firmware 3006.102_37000
or greater, then you first need to enable downgrade
capabilities before flashing Asuswrt-Merlin on top
of it. Connect Over SSH, and run the following command:
nvram set DOWNGRADE_CHECK_PASS=1
After that, you can upload Asuswrt-Merlin through
the webui like any regular firmware upgrade.
This is only required when flashing Asuswrt-Merlin
for the first time.
You indicated doing a factory reset, did you try doing a hard factory reset? A hard factory reset is slightly different than a factory reset.
[Wireless Router] When Standard Reset Isn’t Working: Hard Factory Reset - Models list
[Wireless Router] ASUS router Hard Factory Reset - Method 2
1. Turn the router off.
2. Press and hold the WPS button and turn the router on.
3. Power light is on (keep holding the WPS button).
4. Release the WPS button after the power light is off.
5. Reboot your router by manually pressing the power button.
In general terms this is how AI explains it:
"The metric in a static route list on an ASUS router indicates the priority of the route; a lower metric value means a higher priority. This helps the router decide which route to use when multiple routes to the same destination exist."
Yup. I basically hooked it up to my ChromeOS laptop out of the box to do enough preliminary setup to enable SSH, do the nvram thing, then upload Merlin.
Method 2. Well and truly nuked. :-)
You indicated you "... painstakingly set up all my personalization" and were using a firewall-start script that is "admittedly a bit on the large side." As a troubleshooting step if you want to try Asus-Merlin again is to manually configure the router with very the absolute minimum number of non default settings then test the router. Do not use a firewall-start script file until you can verify the router working as expected with the basic limited settings.
Also its entirely possible if one used certain values or settings on an earlier Asus router that runs a different firmware track; those settings may, in likely very rare cases, possibly cause configuration issues with the 3006.102.x firmware. Best to try and use default settings where possible initially to verify the new router is working properly.
Yeah, my immediate goal was to eliminate "bad hardware" as a suspect by going back to stock.
I did try with a vastly minimized firewall-start, but admittedly not *no* firewall-start. Next iteration, I'll definitely do that.
My settings, in the end, were fairly minimalist. I had a bunch of manual IP assignments originally via a dnsmasq.conf.add file on the previous (RT-AC86U) that I copied'n'pasted into the GUI on the 92U (since it now has a higher limit). That was the most painful part.
The one clue from the log is literally hundreds and hundreds of "mroute: pending queue full, dropping entries" lines, interspersed with "net_ratelimit: 7 callbacks suppressed" every dozen'ish. Then eventually "rcu: INFO: rcu_preempt self-detected stall on CPU", and it would reboot soon after. Googling reveals a few places where somebody asks what that first error means, but I haven't yet found an answer.
i bet most likely was because u used a conf from an old device? i didnt have any issue using Merlin on my BE92U though. No crashed, nothing. all doing good.
No importation was done at all. I know that's a bad thing. I literally re-entered each and every setting manually in the GUI. And there really weren't all that many.
But the fact it's not a common problem, despite the 92U being a new addition, bodes well. So I'll try again next release and take a more measured approach.
@bpsmicro, Another troubleshooting step for when you setup Asus-Merlin again. Don't setup AiMesh right off the bat. Get the router working first then add AiMesh later.
Keep in mind that the Asus-Merlin 3006 firmware is a major departure from the 386 and 388 Asus-Merlin firmware. If you used the same firewall-start script file (or code) that was used on either 386 or 388 firmware you should review that code. There are a number of past posted in the subforum on using firewall-start scripting on 3006 firmware. In certain cases one has to use different values due to the new inclusion of Guest Network Pro, VLAN and SDN features.
Thanks for that. I'll go hunting for the notes on firewall-start. I've never used the features you mention, but I'll see if I can find any clues.
I find in general each new generation of Asus router seems to have crappier and crappier 5GHz range than the ones before, so AIMesh becomes pretty mandatory fairly quickly. Even now with my 3-node mesh running I find the 5GHz coverage pretty lacking. :-(
Yes but not quite; at least not in the HW sense, as I already wrote before it is just legislation per country/area(EU).
If you change that (#a), you will see just how strong the signal can be.
Bought a RT-BE88U last week. Yesterday replaced the stock firmware with Merlin firmware 3006.102.4.
Spent some time configuring. Pleasantly surprised with Wireguard and the new network setup (guest, kids, iot, etc.)
The router is working smoothly!
I have setup 4 different OVPN clients and 2 Wireguard clients. In one of the WG client I have an error. That resulted in a total shutdown of all VPN clients. After disabling the faulty WG client everything worked as expected. Would have been nice if this faulty WG client would'nt drag all VPN clients down, but the fix is simple so not really an issue.
So I upgraded and the guest network pro does not seem to be working correctly. If I configure Guest network pro to use different subnet, DHCP does not work even when configured under guest network pro for that subnet.... devices do not get an IP. I can manually assign the correct IP and the new guest network pro works so I confirmed it is DHCP. The only way to get my IOT to work without YAZFI now is to have them on all the same subnet which defeats the purpose.
Has anyone figured out how to get DHCP to work for a guest network Pro VLAN? I am using a AX88U pro.
