Error upgrading RT-AC68U from 380.69 to 380.69_2
Naving
Hi!
I'm currently running 380.69 on my RT-AC68U.
However, when I try to upgrade to 380.69_2 I get a following error
Invalid Firmware Upload
Firmware upgrade unsuccessful. This might result from incorrect image or error transmission, please check the model name RT-AC68U and version of firmware from support site and try again.
The checksum of my RT-AC68U_380.69_2.trx is as expected (c1251b1a2facf0dd2920451e5ba0f296e133913a9c199ca4bccaadf0d091f546).
Can you please advise what may be the cause of this issue?
I had same error a decompress the file moved it to different folder and did it again it works well before trying reboot your router
Sent from my SAMSUNG-SM-G920AZ using Tapatalk
I tried restarting the router, moving the trx file into a different directory and even renaming it. Still no luck. Any other ideas?
