FaceTime not connecting on the iPhone while on Asus RT-aC68u
chercm
what should about this ?
i read about the firewall rule and i tried to setup the rule but still not able to be connected
i read some where that the uPNP function on the Asus routers are broken
That'd be the first time I ever heard this one.
Works just fine between multiple iPhones on Asuswrt-Merlin 3.0.0.4.374.38_2
Sounds like you might need to tell us a few more details about your setup (router and phone).
What I would do is upgrade to the latest firmware on the router and do a proper reset and enter any settings needed manually.
Also; 'forget' the network setting for the current ssid on your phone and re-associate it (this you can try before and after upgrading the firmware).
With the firmware version known along with the proper resetting to defaults - the phone should work for you.
Did you upgrade without resetting to defaults? Did you restore your settings from a backup after upgrading? What versions are the firmware on the router and phone?
Did you play with any settings in the router or phone? Is the phone jailbroken?
More information may allow someone to help you more.
stupid me . i did not manually enter the settings . i restored the default and every thing worked .
thanks
Glad to hear you got it fixed! Can't live without the facetime! :)
