filefrag command
noric
I'd like to use this script to check file fragmentation:
#!/usr/bin/perl -w
#this script search for frag on a fs
use strict;
#number of files
my $files = 0;
#number of fragment
my $fragments = 0;
#number of fragmented files
my $fragfiles = 0;
my $verbose;
if ($ARGV[0] eq '-v') { shift @ARGV; $verbose++; }
open (REPORT, "find " . $ARGV[0] . " -xdev -type f -print0 | xargs -0 filefrag |");
while (defined (my $res = <REPORT>)) {
        if ($res =~ m/.*:\s+(\d+) extents? found$/) {
                my $fragment = $1;
                $fragments += $fragment;
                if ($fragment > 1) {
                        $fragfiles++;
                $files++;
        } else {
                print ("Failed to parse: $res\n");
close (REPORT);
if ($verbose) {
   print "Total files:      $files\n";
   print "Fragmented files: $fragfiles\n";
   print "Fragments:        $fragments\n";
sub round($$) {
   my $v = shift; # value
   my $p = shift; # rouding divisor (1 for '123', 10 for '123.4', 100 for '123.45')
   return int($v * $p) / $p;
print ( $fragfiles / $files * 100 . "% non contiguous files, " . $fragments / $files . " average fragments.\n");
As you can see it needs the filefrag command, that appears to be missing. I've tried to install e2fsprogs (from entware) but it doesn't include filefrag.
Do you know where can I find it?
Thanks.
That's what I thought when I installed e2fsprogs, but it's not there.
Could it be that the entware package of e2fsprogs is different than optware's? This is what I think I understood from a Russian forum using google translate.
Now the script runs, but I encounter the following error:
Failed to parse: /mnt/sda1/Media/<<video1.avi>>: 13 extents found, perfection would be 7 extents
Failed to parse: /mnt/sda1/Media/<<video2.avi>>: 17 extents found, perfection would be 12 extents
0% non contiguous files, 1 average fragments.
I see where the error is in the code, but I have no idea what is causing it. :(
In case anyone wants to achieve the same as I wanted, I've adopted a simpler solution. I installed e2fsprogs from entware:
opkg install e2fsprogs
and then I manually use this command:
filefrag /folder/you/want/to/check/*
Easy as that.
