Is there any reason the 'find' command on the routers are missing tons of actions compared to the BusyBox documentation? Specifically -type and -maxdepth?
This:
VS This:
This:
BusyBox v1.24.1 (2018-03-10 13:31:44 EST) multi-call binary.
Usage: find [-HL] [PATH]... [OPTIONS] [ACTIONS]
Search for files and perform actions on them.
First failed action stops processing of current file.
Defaults: PATH is current directory, action is '-print'
-L,-follow Follow symlinks
-H ...on command line only
Actions:
! ACT Invert ACT's success/failure
ACT1 [-a] ACT2 If ACT1 fails, stop, else do ACT2
ACT1 -o ACT2 If ACT1 succeeds, stop, else do ACT2
Note: -a has higher priority than -o
-name PATTERN Match file name (w/o directory name) to PATTERN
-iname PATTERN Case insensitive -name
-mtime DAYS mtime is greater than (+N), less than (-N),
or exactly N days in the past
If none of the following actions is specified, -print is assumed
-print Print file name
-print0 Print file name, NUL terminated
-exec CMD ARG ; Run CMD with all instances of {} replaced by
file name. Fails if CMD exits with nonzero
VS This:
find [PATH]... [EXPRESSION]
Search for files. The default PATH is the current directory, default EXPRESSION is '-print'
EXPRESSION may consist of:
-xdev Don't descend directories on other filesystems
-maxdepth N Descend at most N levels. -maxdepth 0 applies
tests/actions to command line arguments only
-mindepth N Don't act on first N levels
-name PATTERN File name (w/o directory name) matches PATTERN
-path PATTERN Path matches PATTERN
-regex PATTERN Path matches regex PATTERN
-type X File type is X (X is one of: f,d,l,b,c,...)
-perm NNN Permissions match any of (+NNN), all of (-NNN),
or exactly NNN
-mtime DAYS Modified time is greater than (+N), less than (-N),
or exactly N days
-mmin MINS Modified time is greater than (+N), less than (-N),
or exactly N minutes
-newer FILE Modified time is more recent than FILE's
-inum N File has inode number N
-user NAME File is owned by user NAME (numeric user ID allowed)
-group NAME File belongs to group NAME (numeric group ID allowed)
-depth Process directory name after traversing it
-size N[bck] File size is N (c:bytes,k:kbytes,b:512 bytes(def.))
+/-N: file size is bigger/smaller than N
-links N Number of links is greater than (+N), less than (-N),
or exactly N
-print Print (default and assumed)
-print0 Delimit output with null characters rather than
newlines
-exec CMD ARG ; Run CMD with all instances of {} replaced by the
matching files
-prune Stop traversing current subtree
-delete Delete files, turns on -depth option
(EXPR) Group an expression
