Firmware 3.0.0.4.380.1842 Available for RT-AC68U
sol1109
Just noticed updated firmware available at the Asus support page. Below is the information posted with it. I have not tried it yet.
Version 3.0.0.4.380.1842
Description ASUS RT-AC68U Firmware version 3.0.0.4.380.1842
Bug fixes
- Fixed Multicast issue when WAN is PPPoE/ PPTP/ L2TP
- Fixed IPTV GUI issue
- Fixed two guest networks had same mac address problem.
- Fixed view list in network map cannot be closed.
- Fixed network map device icon issue
- Fixed client cannot get new IP when changed router IP and subnet mask.
- Fixed wrong notification when using quick internet setup wizard in static IP environment.
- Fixed wrong notification when client was blocked by Time scheduling.
- Fixed ASUS Router App related issues.
- Fixed DNS response error issue.
- Fixed abnormal LED blinking issue when enabled IPTV.
- Fixed client list name cannot be changed issue.
MD5:2884cb7c5a2c4d22ff609ccfbf388c32
File Size 34.86 MBytesupdate 2016/01/28
I did check. Did not show up in my search using the search box since it is a different group. Past updates for AC routers used to always be in this group. Looks like that group was started back in September, thanks for pointing it out.
I had to go back to release 3.0.0.4.378.9313 . My Netatmo will not work with any of the newer releases. Hopefully this issue will be resolved.
