Ripshod
Part of the Furniture
Previous to the upgrade from 386.7_2 all my scripts were working fine. Since I upgraded NTP updates are not happening. I've tried a dirty flash, a clean flash after a nuclear reset then ran all day today with several reboots without ntpMerlin and everything was sweet. As soon as I add ntpMerlin and reboot NTP fails.
In the logs I have this repeated:
May 5 06:12:44 timeserverd: Waiting for NTP to sync...
May 5 06:12:45 connmon: Waiting for NTP to sync...
May 5 06:12:45 ntpMerlin: Waiting for NTP to sync...
May 5 06:12:45 uiDivStats: Waiting for NTP to sync...
May 5 06:12:45 spdMerlin: Waiting for NTP to sync...
Then later
May 5 06:15:25 taildns: NTP failed to sync after 10 minutes - please check immediately!
Obviously the date and time are wrong due to the ntp error
It's stopping all the UI elements loading so all I get is the bog standard. amtm works but nothing will run due to the lock file. You thoughts?
Then later
