flat coax for window pass thru
metropical
Upgrading network to ready for 300/300.
FiOS ONT outside. Going to move my G1100 gateway close to it and convert to Ethernet with Frontier FCA252 using the existing RG6 to an office.
But I'd rather not drill a hole thru the outside wall.
Will a flat coax patch be ok "thru" the window, or is the signal loss too great?
It'd be ONT to G1100 via <5' CAT. CAT from G1100 to FCA252 with a short jumper. FCA252 to flat coax to existing RG6 outside to 2nd FCA252 in the office.
If the one flat is OK, are there preferred ones, or are they all the same?
One TV, iPad, 3 computers & 2 phones. No gaming. No cable TV.
Make sure there are no crimps/folds in the flat if you use it. i wasn't aware flat coax was a thing due to spacing requirements of the shield from the center conductor. Make sure any cable used matches 75 ohm if the supply coax is RG6 or 59 assuming in US.
Why not bore the hole through the wall or find another easier entry point ?
You could even go through the eave of the roof and come down somewhere in the building if you don't want to go through an exterior wall.
Brett Stimpson loose coax? moca help MoCA, HomePlug, HPNA 10
