FTP over TLS or SSL setup
jappish84
Ok, so I found an old thread here https://www.snbforums.com/threads/merlin-firmware-anyway-to-encrypt-ftp.21317/ that pretty much covers my question.
Basically, I would like to find a way to secure the FTP server on Merlin FW. I'm using RT-AC3200.
@redhat27 you mentioned SCP could be an alternative, but if I understood that correctly that would be like SFTP where adding users with different read/write permissions would require me to add users to the router using SSH, right?
I have a few friends and family that are accessing my FTP server, I don't want them to have access to anything else.
@RMerlin you mentioned TLS support was added with 376.49? Is there some documentation or guide on how to set it up?
It's all on the forums, unless someone added a Wiki article about it - I didn't look.
For scp, you can use any user that is already existing on your router. There is no need to create additional users. For a user with low privileges, use user nobody or set up a suitable user with low privilege
EDIT: I think using nobody will not work. Also, have not setup new users myself. But you can take a look here.
