I have installed latest GNUTON (MERLIN) firmware in my RT-AX82U working as gateway, with RT-AX57 in wired AP mode
I had some problems with certain IoT devices in RT-AX82U. Now, WLAN is solid as a rock.
GNUTON firmware has all things I want. Now I am doing about 100 Mb/s WIREGUARD, In the lower limit I need.
I understand BCM6750 limits, and I think only a bit more power should increase WIREGUARD speed to optimal value for me (about 150-160 Mb/s)
I can find TUF AX3000 V2, with BCM6756 (1,7 Ghz quad core) vs BCM 6750 (1,5 Ghz tricore)
The question is if AX3200 V2 with quad core CPU can increase WIREGUARD speed over BCM6750.
AX3000 V2 is compatible with GNUTON firmware. Rt-AX82U woul be the wired AP
