Not normal. As a troubleshooting step, did you reset the RT-AX58U prior to connecting to the Fiber's Ethernet line? Reset the Asus router, manually reconfigure it (without importing a saved router.cfg file) with default settings then test again.Got fiber today (1GB) if by passing the supplied router Erro 6 and connecting to the Asus AX58U my download speed is 600 or if using the Erro 6 and not using the Asus, DL speeds are 900 or so
Is that normal?
No I did notNot normal. As a troubleshooting step, did you reset the RT-AX58U prior to connecting to the Fiber's Ethernet line? Reset the Asus router, manually reconfigure it (without importing a saved router.cfg file) with default settings then test again.
Welcome To SNBForums
