grep: /opt/var/log/dnsmasq.log: binary file matches
ColinJOnes
Hi, I am trying to use the autoscan.sh script that comes x3mrouting and am getting an error. This is the command I am running but it doesn't work (It doesn't work when I search for anything).
./autoscan.sh autoscan=netflix
I do have these lines in the dnsmasq.conf.add file and the dnsmasq.log file does exists and it contains data
log-async
log-queries
log-facility=/opt/var/log/dnsmasq.log
If I run
cat /opt/var/log/dnsmasq.log |grep netflix --binary-files=text
I get lots of results back.
This used to work previously but recently started throwing up the error and was wondering if anybody had any ideas.
IPSET Format
FQDN Format
Thank you in advance.
Either clear the log file or search for binary character(s) in the file and remove it/them.
I posted as I didn't know how to clear the log file without deleting it and unfortunately I don’t know how to search for binary characters or even know what they are.
thanks for you help though. I resolved by stoping the service, deleting file and starting service again
Next time it happens, try this to keep the existing dnsmasq log file.
You'll need Entware grep installed which Diversion and maybe other scripts install by default.
If /opt/bin/grep is missing install it with
opkg install grep
Check if the log file contains NULL characters:
/opt/bin/grep -Pa '\x00' /opt/var/log/dnsmasq.log
If any are found, then you may remove them using:
tr < /opt/var/log/dnsmasq.log -d '\x00' > /opt/var/log/dnsmasq_cleared.log
Check if those pesky characters are gone in the temp file:
/opt/bin/grep -Pa '\x00' /opt/var/log/dnsmasq_cleared.log
If so, move it and restart Dnsmasq:
mv -f /opt/var/log/dnsmasq_cleared.log /opt/var/log/dnsmasq.log
service restart_dnsmasq
S Entware Lost /opt/bin files Asuswrt-Merlin AddOns 4
