GT-AX6000 Merlin 388.2_2_rog client list capped
ronzino
Hi guys,
I wonder if it is an official asus implementation/bug, but client list is limited to 30 clients !
The others are not listed, even if they receive from the DHCP an ip and can operate perfectly on the network.
is there a way to unlimit the number of listed clients ?
of course, there is no reason to say, that will be hard to manage/configure network without knowing which clients are connected as well as the ip address they have got
It's not limited on the non-ROG version, I have 33 clients showing right now, so I'm not sure why it would be limited on the ROG version.
my advice upgrade it to the latest version or even beta 1 from 388.6 it's very stable.
Are you talking about Asus original version?
No merlins version the latest one is 388.6 it’s super stable had has fixed that capped client list.
I think there are still some problems with the client list. for example, I just assigned a fixed IP to a PC, changing it from the one assigned by DHCP but it doesn't change in the client list. to see the change I have to restart the router.
When I had the GT-AX6000 as my router, I had well over 50 clients with the ROG version. It was a mix of static and dynamic clients, and I had no issues. I went to Merlins FW as soon as it was available, but I believe I had just as many clients before I switched over to the FW.
It's a node now, with the 16000 as the router, but I took a look at the client list I exported, and it had 56 devices. I definitely recommend switching over to Merlin anyway, but also ensure you do a hard reset and take a look at your pools to make sure they don't have a typo and could be limiting the number of clients you can get assignments for. Lord knows I had stupid typos in my life.
