Beta Asuswrt-Merlin 3006.102.4 Beta is now available
Just installed Beta 3b on RT-BE92U running as a main router everything working great.
Only thing I could find are these errors:
May  7 20:12:35 networkmap: Error locking /var/lock/networkmap.lock: 0 Already locked
May  7 20:12:35 networkmap: Error unlocking -1: 9 Bad file descriptor
Those errors have been part of asuswrt firmware since........ that long ago I can't remember 😐
Beta 3 - No issues so far on my BE96U. Logs seen are just normal start up stuff and a device that seems to reboot itself or the port every 24 hours. It's not a router issue.
Dirty upgrade on RT-AX86U Pro. Working well. No issues. Looks good on my end.
I second that. No issues whatsoever for me.
Maybe we need a plug-in to highlight logs which is known to be benign/not critical with a different colour so users will be able to differentiate.
Smooth sailing since I installed beta3 three days ago.
Node backhaul at 2.5 GB, core switch connected via link aggregation (port 1-2), iot wlan/vlan (port 3).
5GHz network bandwidth 160 MHz @ channel 48.
MANY THANKS to RMerlin!
Dear all,
For many years I am following this forum. The community helped me very much over the last 2 decades, kudos! I decided to try this latest beta as I would like to test the Guest Network Pro functionality and IoT setup with all my devices at home. I upgraded and almost everything seems to work normally. YazDHCP had to be updated to developer version (1.0.7) for all the leased IPs to display properly. After playing a little bit I understood Adguard is not working properly with all the different VLANs created in Guest Network Pro. For the moment I removed Adguard and move the service on a PI-Hole installation in my lab. The issue I am struggling to make it work is the Guest Portal. Setup seems to be proper and I do get the portal with the "Continue" button. However when clicking on it I get a fail message from http://192.168.53.1 (VLAN subnet). Is there any reason why is this happening?
Dear all,
I have a similar issue with Captive portals on my end. I saw other reports as well found below: https://www.snbforums.com/threads/asuswrt-merlin-3006-102-4-beta-is-now-available.94366/post-952904
I can't get the guest portals working. I can activate them and let them show in my network list, but they can't connect to it. I have AGH active and Skynet. Maybe that is the problem. In the logs I see an entry dnsmasq that is giving the problem. Has anyone an solution?
But unlike him; I don't have AGH active or Skynet.
Here is my setup (no Intranet access) and the error I receive:
Connecting error:
View attachment 65530View attachment 65532
Connecting error:
exactly the same user experience. I also don't have AGH and Skynet installed. I think this is an area for improvement in future releases.
After installing the Beta 3, I have lost access to my cable modem at http://192.168.100.1/ . My network router runs on http://192.168.50.1/ and following. Did the update drop or change anything that would cause that bit of weirdness?
Do you see uamsrv crashing in your syslog?
May  8 12:11:02 kernel: potentially unexpected fatal signal 11.
May  8 12:11:02 kernel: CPU: 0 PID: 11939 Comm: uamsrv Tainted: P           O      4.19.183 #1
May  8 12:11:02 kernel: Hardware name: RTAX88U_PRO (DT)
May  8 12:11:02 kernel: pstate: 80000010 (Nzcv q A32 LE aif)
May  8 12:11:02 kernel: pc : 00000000f6d6cd20
May  8 12:11:02 kernel: lr : 0000000000035608
May  8 12:11:02 kernel: sp : 00000000ffdf62a8
May  8 12:11:02 kernel: x12: 0000000000051478
May  8 12:11:02 kernel: x11: 0000000000000001 x10: 000000000001e214
May  8 12:11:02 kernel: x9 : 0000000000000006 x8 : 0000000000039e7b
May  8 12:11:02 kernel: x7 : 000000000176d42a x6 : 0000000000000002
May  8 12:11:02 kernel: x5 : 000000000176d190 x4 : 0000000000000000
May  8 12:11:02 kernel: x3 : 0000000001783948 x2 : 0000000000000000
May  8 12:11:02 kernel: x1 : 0000000000000022 x0 : 0000000000000000
Yessir this is mine from my test this morning while replicating the reports:
May  8 10:15:32 kernel: potentially unexpected fatal signal 11.
May  8 10:15:32 kernel: CPU: 2 PID: 12581 Comm: uamsrv Tainted: P           O      4.19.294 #1
May  8 10:15:32 kernel: Hardware name: Broadcom-v8A (DT)
May  8 10:15:32 kernel: pstate: 80000010 (Nzcv q A32 LE aif)
May  8 10:15:32 kernel: pc : 00000000f7223a50
May  8 10:15:32 kernel: lr : 00000000000359a8
May  8 10:15:32 kernel: sp : 00000000ffbc7240
May  8 10:15:32 kernel: x12: 000000000005147c
May  8 10:15:32 kernel: x11: 0000000000000001 x10: 000000000001e320
May  8 10:15:32 kernel: x9 : 000000000003a417 x8 : 000000000041e960
May  8 10:15:32 kernel: x7 : 00000000003a542a x6 : 0000000000000002
May  8 10:15:32 kernel: x5 : 00000000003a5190 x4 : 0000000000000000
May  8 10:15:32 kernel: x3 : 00000000003bad80 x2 : 0000000000000000
May  8 10:15:32 kernel: x1 : 0000000000000022 x0 : 0000000000000000
for me the failure is on amas_lib because I have mesh network enabled:
May  8 20:26:44 kernel: Can't add zero mac!
May  8 20:26:44 kernel: CPU: 3 PID: 1095947 Comm: amas_lib Tainted: P           O      4.19.183 #1
May  8 20:26:44 kernel: Hardware name: RTAX88U_PRO_gpy211 (DT)
May  8 20:26:44 kernel: pstate: 600b0010 (nZCv q A32 LE aif)
May  8 20:26:44 kernel: pc : 00000000f70358fc
May  8 20:26:44 kernel: lr : 00000000f700daac
May  8 20:26:44 kernel: sp : 00000000f6f86fd0
May  8 20:26:44 kernel: x12: 0000000000000025
May  8 20:26:44 kernel: x11: 00000000f6f874bc x10: 00000000002a1ec4
May  8 20:26:44 kernel: x9 : 00000000f6f89ad0 x8 : 00000000f70fc000
May  8 20:26:44 kernel: x7 : 0000000000000000 x6 : 00000000f74a7687
May  8 20:26:44 kernel: x5 : 00000000fbad8004 x4 : 00000000f6f874d0
May  8 20:26:44 kernel: x3 : 00000000f74a7688 x2 : 0000000000000045
May  8 20:26:44 kernel: x1 : 0000000000000025 x0 : 00000000f74a7688
I have a mesh network as well.
Did anyone tested gree air conditioner with Asuswrt-Merlin 3006.102.4. I have two XT12 and all 3 units of gree AC in my home won't connect to wifi. On the second
XT12 (configured as AiMesh node) I install also official 3006 firmware and It didn't helped. After installing 3004.388.8_4 on XT12 (node) the gree AC connect to this node without any problems.
I haven't tried to make sense of it yet, but the strace of the uamsrv before it dumps is below. Interestingly, I could not make it crash using my iPad. Only a windows machine made it crash.
epoll_wait(9, [{events=EPOLLIN, data={u32=6, u64=6}}], 1025, 1000) = 1
accept(6, {sa_family=AF_INET, sin_port=htons(50741), sin_addr=inet_addr("192.168.52.4")}, [112 => 16]) = 10
fcntl64(10, F_SETFD, FD_CLOEXEC)        = 0
fcntl64(10, F_SETFL, O_RDWR|O_NONBLOCK) = 0
ioctl(10, FIONREAD, [710])              = 0
read(10, "GET /FreeUam?res=notyet&uamip=19"..., 4159) = 710
stat64("/tmp/uamsrv/www/FreeUam.html", 0xff8322b8) = 0
openat(AT_FDCWD, "/tmp/uamsrv/www/FreeUam.html", O_RDONLY|O_LARGEFILE) = 11
close(11)                               = 0
setsockopt(10, SOL_TCP, TCP_CORK, [1], 4) = 0
writev(10, [{iov_base="HTTP/1.1 200 OK\r\nSet-Cookie: TRA"..., iov_len=340}], 1) = 340
openat(AT_FDCWD, "/tmp/uamsrv/www/FreeUam.html", O_RDONLY|O_NOCTTY|O_LARGEFILE) = 11
fcntl64(11, F_SETFD, FD_CLOEXEC)        = 0
_llseek(11, 0, [0], SEEK_SET)           = 0
read(11, "\357\273\277<meta charset='UTF-8'>\n<meta "..., 8304) = 8304
write(10, "\357\273\277<meta charset='UTF-8'>\n<meta "..., 8304) = 8304
close(11)                               = 0
setsockopt(10, SOL_TCP, TCP_CORK, [0], 4) = 0
ioctl(10, FIONREAD, [0])                = 0
read(10, 0x11ac628, 4159)               = -1 EAGAIN (Resource temporarily unavailable)
epoll_ctl(9, EPOLL_CTL_ADD, 10, {events=EPOLLIN|EPOLLERR|EPOLLHUP, data={u32=10, u64=10}}) = 0
accept(6, 0xff8348f8, [112])            = -1 EAGAIN (Resource temporarily unavailable)
epoll_ctl(9, EPOLL_CTL_MOD, 10, {events=EPOLLIN|EPOLLERR|EPOLLHUP, data={u32=10, u64=10}}) = 0
gettimeofday({tv_sec=1471891334035068, tv_usec=487392906703248}, NULL) = 0
epoll_wait(9, [{events=EPOLLIN, data={u32=10, u64=10}}], 1025, 1000) = 1
ioctl(10, FIONREAD, [739])              = 0
read(10, "GET /FreeUam.css HTTP/1.1\r\nHost:"..., 4159) = 739
stat64("/tmp/uamsrv/www/FreeUam.css", 0xff8322e8) = 0
openat(AT_FDCWD, "/tmp/uamsrv/www/FreeUam.css", O_RDONLY|O_LARGEFILE) = 11
close(11)                               = 0
writev(10, [{iov_base="HTTP/1.1 200 OK\r\nVary: Accept-En"..., iov_len=268}], 1) = 268
openat(AT_FDCWD, "/tmp/uamsrv/www/FreeUam.css", O_RDONLY|O_NOCTTY|O_LARGEFILE) = 11
read(11, "\357\273\277body{\n\tmargin: 0;\n\tbackground"..., 27229) = 27229
write(10, "\357\273\277body{\n\tmargin: 0;\n\tbackground"..., 27229) = 27229
close(11)                               = 0
read(10, 0x11ac770, 4159)               = -1 EAGAIN (Resource temporarily unavailable)
gettimeofday({tv_sec=1998617533281916, tv_usec=487392906703248}, NULL) = 0
accept(6, {sa_family=AF_INET, sin_port=htons(50743), sin_addr=inet_addr("192.168.52.4")}, [112 => 16]) = 11
fcntl64(11, F_SETFL, O_RDWR|O_NONBLOCK) = 0
ioctl(11, FIONREAD, [721])              = 0
read(11, "GET /jquery.js HTTP/1.1\r\nHost: 1"..., 4159) = 721
stat64("/tmp/uamsrv/www/jquery.js", 0xff8322b8) = 0
openat(AT_FDCWD, "/tmp/uamsrv/www/jquery.js", O_RDONLY|O_LARGEFILE) = 12
close(12)                               = 0
setsockopt(11, SOL_TCP, TCP_CORK, [1], 4) = 0
writev(11, [{iov_base="HTTP/1.1 200 OK\r\nContent-Type: t"..., iov_len=253}], 1) = 253
openat(AT_FDCWD, "/tmp/uamsrv/www/jquery.js", O_RDONLY|O_NOCTTY|O_LARGEFILE) = 12
fcntl64(12, F_SETFD, FD_CLOEXEC)        = 0
_llseek(12, 0, [0], SEEK_SET)           = 0
read(12, "/*! jQuery v3.7.1 | (c) OpenJS F"..., 65536) = 65536
write(11, "/*! jQuery v3.7.1 | (c) OpenJS F"..., 65536) = 65536
fstat64(12, 0xff832308)                 = 0
_llseek(12, 65536, [65536], SEEK_SET)   = 0
read(12, "opFix:{\"for\":\"htmlFor\",\"class\":\""..., 35261) = 35261
write(11, "opFix:{\"for\":\"htmlFor\",\"class\":\""..., 35261) = 35261
close(12)                               = 0
setsockopt(11, SOL_TCP, TCP_CORK, [0], 4) = 0
ioctl(11, FIONREAD, [0])                = 0
read(11, 0x11adac0, 4159)               = -1 EAGAIN (Resource temporarily unavailable)
epoll_ctl(9, EPOLL_CTL_ADD, 11, {events=EPOLLIN|EPOLLERR|EPOLLHUP, data={u32=11, u64=11}}) = 0
accept(6, {sa_family=AF_INET, sin_port=htons(50744), sin_addr=inet_addr("192.168.52.4")}, [112 => 16]) = 12
fcntl64(12, F_SETFL, O_RDWR|O_NONBLOCK) = 0
ioctl(12, FIONREAD, [719])              = 0
read(12, "GET /uam.js HTTP/1.1\r\nHost: 192."..., 4159) = 719
stat64("/tmp/uamsrv/www/uam.js", 0xff8322b8) = 0
openat(AT_FDCWD, "/tmp/uamsrv/www/uam.js", O_RDONLY|O_LARGEFILE) = 13
close(13)                               = 0
setsockopt(12, SOL_TCP, TCP_CORK, [1], 4) = 0
writev(12, [{iov_base="HTTP/1.1 200 OK\r\nContent-Type: t"..., iov_len=251}], 1) = 251
openat(AT_FDCWD, "/tmp/uamsrv/www/uam.js", O_RDONLY|O_NOCTTY|O_LARGEFILE) = 13
fcntl64(13, F_SETFD, FD_CLOEXEC)        = 0
_llseek(13, 0, [0], SEEK_SET)           = 0
read(13, "var username = getUrlVars()[\"use"..., 6072) = 6072
write(12, "var username = getUrlVars()[\"use"..., 6072) = 6072
close(13)                               = 0
setsockopt(12, SOL_TCP, TCP_CORK, [0], 4) = 0
ioctl(12, FIONREAD, [0])                = 0
read(12, 0x11adac0, 4159)               = -1 EAGAIN (Resource temporarily unavailable)
epoll_ctl(9, EPOLL_CTL_ADD, 12, {events=EPOLLIN|EPOLLERR|EPOLLHUP, data={u32=12, u64=12}}) = 0
epoll_ctl(9, EPOLL_CTL_MOD, 11, {events=EPOLLIN|EPOLLERR|EPOLLHUP, data={u32=11, u64=11}}) = 0
epoll_ctl(9, EPOLL_CTL_MOD, 12, {events=EPOLLIN|EPOLLERR|EPOLLHUP, data={u32=12, u64=12}}) = 0
gettimeofday({tv_sec=2092157626021500, tv_usec=487392906703248}, NULL) = 0
epoll_wait(9, [{events=EPOLLIN, data={u32=11, u64=11}}], 1025, 1000) = 1
ioctl(11, FIONREAD, [723])              = 0
read(11, "GET /FreeUam.json HTTP/1.1\r\nHost"..., 4159) = 723
stat64("/tmp/uamsrv/www/FreeUam.json", 0xff8322e8) = 0
openat(AT_FDCWD, "/tmp/uamsrv/www/FreeUam.json", O_RDONLY|O_LARGEFILE) = 13
close(13)                               = 0
writev(11, [{iov_base="HTTP/1.1 200 OK\r\nContent-Type: a"..., iov_len=196}], 1) = 196
openat(AT_FDCWD, "/tmp/uamsrv/www/FreeUam.json", O_RDONLY|O_NOCTTY|O_LARGEFILE) = 13
read(13, "{\"splash_page_setting\":{\"image\":"..., 65536) = 65536
write(11, "{\"splash_page_setting\":{\"image\":"..., 65536) = 65536
fstat64(13, 0xff832338)                 = 0
_llseek(13, 65536, [65536], SEEK_SET)   = 0
read(13, "dvIzzy+V3BylkxJJhxJs8bMkssjgEEIQ"..., 40499) = 40499
write(11, "dvIzzy+V3BylkxJJhxJs8bMkssjgEEIQ"..., 40499) = 40499
close(13)                               = 0
gettimeofday({tv_sec=2512815312926332, tv_usec=487392906703248}, NULL) = 0
ioctl(11, FIONREAD, [706])              = 0
read(11, "GET /favicon.ico HTTP/1.1\r\nHost:"..., 4159) = 706
stat64("/tmp/uamsrv/www/favicon.ico", 0xff8322e8) = -1 ENOENT (No such file or directory)
stat64("/tmp/uamsrv/www/favicon.ico", 0xff832330) = -1 ENOENT (No such file or directory)
stat64("/tmp/uamsrv/www/index.html", 0xff8322e8) = -1 ENOENT (No such file or directory)
stat64("/tmp/uamsrv/www/index.html", 0xff832330) = -1 ENOENT (No such file or directory)
--- SIGSEGV {si_signo=SIGSEGV, si_code=SEGV_MAPERR, si_addr=NULL} ---
+++ killed by SIGSEGV +++
May  8 14:22:52 kernel: potentially unexpected fatal signal 11.
May  8 14:22:52 kernel: CPU: 2 PID: 26045 Comm: uamsrv Tainted: P           O      4.19.183 #1
May  8 14:22:52 kernel: Hardware name: RTAX88U_PRO (DT)
May  8 14:22:52 kernel: pstate: 808f0010 (Nzcv q A32 LE aif)
May  8 14:22:52 kernel: pc : 00000000f6d60d20
May  8 14:22:52 kernel: lr : 0000000000035608
May  8 14:22:52 kernel: sp : 00000000ff832478
May  8 14:22:52 kernel: x12: 0000000000051478
May  8 14:22:52 kernel: x11: 0000000000000001 x10: 000000000001e214
May  8 14:22:52 kernel: x9 : 0000000000000006 x8 : 0000000000039e7b
May  8 14:22:52 kernel: x7 : 000000000111f42a x6 : 0000000000000002
May  8 14:22:52 kernel: x5 : 000000000111f190 x4 : 0000000000000000
May  8 14:22:52 kernel: x3 : 0000000001134d58 x2 : 0000000000000000
May  8 14:22:52 kernel: x1 : 0000000000000022 x0 : 0000000000000000
close(11)                               = 0
close(11)                               = 0
close(11)                               = 0
close(11)                               = 0
close(12)                               = 0
close(12)                               = 0
close(13)                               = 0
close(13)                               = 0
close(13)                               = 0
close(13)                               = 0
I tested it from my Android phone this morning which made it crash. Interesting indeed. So your saying it logged in successfully without crashing on your iPad? I wonder what's different.
