My Macbook Pro and iPhone stopped connecting to my GT-AX6000 AIMesh. It repeatedly self-assigns a 192.168.1.XXX address, no matter how many times I release and renew the DHCP lease. I can connect to the Guest network just fine, oddly enough.
These devices are within 20 feet from the primary station. They've both been connecting fine, and transferring between AI Mesh nodes without consequence during the past two months. Three days ago I'm not able to connect via either iPhone or Macbook no matter how many times that I refresh the IP address or turn off wifi or restart the router.
The log files are littered with the MAC address of my laptop and iPhone being rejected (first batch), or auth/deauth (second batch).
The first batch looks like the A8:98 device (laptop) is being transitioned to the primary router (DD:6C)connected to the modem, and failing to get a response. However, I'm sitting here on the laptop trying to refresh the IP address during this time. In the second batch, I'm also trying to connect and then being self-assigned an IP address.
Interestingly, I can self-assign an IP address in the proper range and access the network, so I'm technically connected to the router.
Any ideas as to why I cannot obtain a proper IP address on these 2 devices?
Jul 22 09:55:43 bsd: bsd: Sending act Frame to AA:AA:AA:AA:A8:98 with transition target eth7 ssid 58:11:22:4e:dd:6c
Jul 22 09:55:44 bsd: bsd: STA:AA:AA:AA:AA:A8:98 no response
Jul 22 09:55:44 bsd: bsd: Sending act Frame to AA:AA:AA:AA:A8:98 with transition target eth7 ssid 58:11:22:4e:dd:6c
Jul 22 09:55:45 bsd: bsd: STA:AA:AA:AA:AA:A8:98 no response
Jul 22 09:55:45 wlceventd: wlceventd_proc_event(645): eth6: Deauth_ind AA:AA:AA:AA:A8:98, status: 0, reason: Previous authentication no longer valid (2), rssi:-47
Jul 22 09:55:46 wlceventd: wlceventd_proc_event(645): eth6: Deauth_ind AA:AA:AA:AA:A8:98, status: 0, reason: Disassociated due to inactivity (4), rssi:-47
Jul 22 09:55:48 wlceventd: wlceventd_proc_event(685): eth6: Auth D6:80:CD
2:9C:12, status: Successful (0), rssi:0
Jul 22 09:55:48 wlceventd: wlceventd_proc_event(695): eth6: ReAssoc D6:80:CD
2:9C:12, status: Successful (0), rssi:-67
Jul 22 09:55:50 bsd: bsd: Sending act Frame to b8:f6:b1:19:82:5d with transition target eth7 ssid 58:11:22:4e:dd:6c
Jul 22 09:55:51 bsd: bsd: STA:b8:f6:b1:19:82:5d no response
Jul 22 09:55:51 bsd: bsd: Sending act Frame to b8:f6:b1:19:82:5d with transition target eth7 ssid 58:11:22:4e:dd:6c
Jul 22 09:55:52 bsd: bsd: STA:b8:f6:b1:19:82:5d no response
Jul 22 09:55:53 wlceventd: wlceventd_proc_event(645): eth6: Deauth_ind B8:F6:B1:19:82:5D, status: 0, reason: Previous authentication no longer valid (2), rssi:-53
Jul 22 09:55:53 crond[2825]: time disparity of 2742470 minutes detected
LATER:
Jul 22 16:04:40 wlceventd: wlceventd_proc_event(685): eth6: Auth ZZ:ZZ:ZZ:ZZ:B9:A8, status: Successful (0), rssi:0
Jul 22 16:04:40 wlceventd: wlceventd_proc_event(722): eth6: Assoc ZZ:ZZ:ZZ:ZZ:B9:A8, status: Successful (0), rssi:-75
Jul 22 16:04:46 wlceventd: wlceventd_proc_event(645): eth6: Deauth_ind ZZ:ZZ:ZZ:ZZ:B9:A8, status: 0, reason: Unspecified reason (1), rssi:-75
Jul 22 16:04:46 wlceventd: wlceventd_proc_event(685): eth6: Auth ZZ:ZZ:ZZ:ZZ:B9:A8, status: Successful (0), rssi:-75
Jul 22 16:04:46 wlceventd: wlceventd_proc_event(722): eth6: Assoc ZZ:ZZ:ZZ:ZZ:B9:A8, status: Successful (0), rssi:-75
Jul 22 16:05:30 wlceventd: wlceventd_proc_event(685): eth7: Auth ZZ:ZZ:ZZ:ZZ:B9:A8, status: Successful (0), rssi:0
Jul 22 16:05:30 wlceventd: wlceventd_proc_event(695): eth7: ReAssoc ZZ:ZZ:ZZ:ZZ:B9:A8, status: Successful (0), rssi:-87
Jul 22 16:06:12 wlceventd: wlceventd_proc_event(645): eth6: Deauth_ind ZZ:ZZ:ZZ:ZZ:B9:A8, status: 0, reason: Disassociated due to inactivity (4), rssi:-79
Jul 22 16:10:09 wlceventd: wlceventd_proc_event(685): eth6: Auth YY:YY:YY:YY:EA:A9, status: Successful (0), rssi:0
Jul 22 16:10:09 wlceventd: wlceventd_proc_event(722): eth6: Assoc YY:YY:YY:YY:EA:A9, status: Successful (0), rssi:-54
Jul 22 16:10:21 wlceventd: wlceventd_proc_event(645): eth6: Deauth_ind YY:YY:YY:YY:EA:A9, status: 0, reason: Disassociated because sending station is leaving (or has left) BSS (8), rssi:0
Jul 22 16:10:21 wlceventd: wlceventd_proc_event(662): eth6: Disassoc YY:YY:YY:YY:EA:A9, status: 0, reason: Disassociated because sending station is leaving (or has left) BSS (8), rssi:0
Jul 22 16:10:28 wlceventd: wlceventd_proc_event(662): eth7: Disassoc AA:AA:AA:AA:A8:98, status: 0, reason: Disassociated because sending station is leaving (or has left) BSS (8), rssi:0
Jul 22 16:10:28 wlceventd: wlceventd_proc_event(645): eth7: Deauth_ind AA:AA:AA:AA:A8:98, status: 0, reason: Deauthenticated because sending station is leaving (or has left) IBSS or ESS (3), rssi:0
Jul 22 16:10:41 wlceventd: wlceventd_proc_event(685): eth7: Auth AA:AA:AA:AA:A8:98, status: Successful (0), rssi:0
Jul 22 16:10:41 wlceventd: wlceventd_proc_event(722): eth7: Assoc AA:AA:AA:AA:A8:98, status: Successful (0), rssi:-53
Jul 22 16:11:05 wlceventd: wlceventd_proc_event(662): eth7: Disassoc AA:AA:AA:AA:A8:98, status: 0, reason: Disassociated because sending station is leaving (or has left) BSS (8), rssi:0
Jul 22 16:11:05 wlceventd: wlceventd_proc_event(645): eth7: Deauth_ind AA:AA:AA:AA:A8:98, status: 0, reason: Deauthenticated because sending station is leaving (or has left) IBSS or ESS (3), rssi:0
Jul 22 16:11:06 wlceventd: wlceventd_proc_event(685): wl1.1: Auth AA:AA:AA:AA:A8:98, status: Successful (0), rssi:0
Jul 22 16:11:06 wlceventd: wlceventd_proc_event(722): wl1.1: Assoc AA:AA:AA:AA:A8:98, status: Successful (0), rssi:-63
Jul 22 16:12:41 wlceventd: wlceventd_proc_event(662): wl1.1: Disassoc AA:AA:AA:AA:A8:98, status: 0, reason: Disassociated because sending station is leaving (or has left) BSS (8), rssi:0
Jul 22 16:12:41 wlceventd: wlceventd_proc_event(645): wl1.1: Deauth_ind AA:AA:AA:AA:A8:98, status: 0, reason: Deauthenticated because sending station is leaving (or has left) IBSS or ESS (3), rssi:0
Jul 22 16:12:41 wlceventd: wlceventd_proc_event(685): eth7: Auth AA:AA:AA:AA:A8:98, status: Successful (0), rssi:0
Jul 22 16:12:41 wlceventd: wlceventd_proc_event(722): eth7: Assoc AA:AA:AA:AA:A8:98, status: Successful (0), rssi:-63
LATER:
