Guest network pro vlan with ethernet ports configured to anything than "All(default) - SDN Profile: default" main dhcp problem
mistermoonlight1
This is a general query
Is there anybody who succesfully configured a guess vlan setup where one of the ethernet port of the switch is not configured to vlan mode All(defaut). I have made tons of test on RT-AX86U Pro using a configuration like this and at some point, it will make me loose main dhcp support to connected ethx client. If the lan ports are all set to vlan mode All(defaut), multiple dhcp configuration seems not to create any problem. I have also tested to create a 7 differents vlan setup created without dhcp (by creating these vlan in the Lan vlan profile section (which is a pain as it will reboot the router each vlan that is added)). With these 7 vlans, i can set the vlan ethernet ports mode anyway i want it (trunk, access, all defaut). But as soon as i convert one of these vlan to support dhcp (through guest network menu), i will loose main ethernet lan dhcp support :-( ...
N.B. if i am configuring more than 1 dhcp server on these vlan ethernet ports (with the 7 vlans setup with ethernet port configured in different vlan modes), all the ethernet ports with dhcp configured will have dhcp working, just the main dhcp will be broken in this situation...
