jj11
Hi all,
I just signed up to a 1Gbps fiber service for home and I'm looking into what hardware I should get to make the best use of it. I've been checking out the Ubiquiti products and they look great, but there doesn't seem to be anything that really fits my needs.
My home setup is simple, as are my needs. I have a NAS and two wired computers, plus a bunch of wifi devices. Everything is in a single network and there's nothing fancy other than a few forwarded ports. I know all the Ubiquiti EdgeRouter products are overkill for my needs, but they're too sexy to resist.
I'm looking for something that could saturate the 1Gbps link, even though I know it's stupid because I'll never saturate it in practice. I'm just uncomfortable buying new kit knowing that it's a bottleneck. I'd like to minimize the number of boxes, so the ideal setup would be an ER-X-SFP plus a wifi router. However, I've read the ER-X-SFP tops out around 800 Mbps, which is too bad. I've read that offloading for the ER-X series is coming, but no word on when. The ERL apparently has the right performance, but then I'd also have to add a switch and a converter, which is a no-go.
My other option right now is a converter and a Netgear R7000. The R7000 is one of the few wifi routers that could saturate the 1Gbps link, but it doesn't support DHCP6-PD. That's not a huge problem, but it would be kind of nice if it did. Also, it's definitely less sexy than an Ubiquiti...
So, do you guys have any recommendations? Should I just go with the boring Netgear R7000, or are there other options I've missed?
