Having some problems with my home network. Please Help!
triggerh4ppy
Hi All,
I need some help with my home network set up:
I currently have a ASUS AC88U as my main router, this is wired to a switch which then provides access to ethernet points all around the house. This has worked great so far allowing me to have wired and wireless access around the house.
I have then added a connection to a newly build external outbuilding also via ethernet which also works fine.
I wanted to also have wired AND wireless access in the outbuilding so decided to connect an old router to the outbuilding ethernet connection and try to use this as an access point, this is where the trouble starts.
My devices either connect to the Main router and work with the internet but then this stops the outbuilding router from connecting to the internet or vice versa. I cant seem to manage to get both running at the same time.
I will sometimes have to physically remove the ethernet going out to the outbuilding before I am able to use the internet using the ASUS router
The ASUS router has the following settings:
IP Address - 192.168.1.1
Subnet Mask - 255.255.255.0
DHCP Server Enabled
IP Pool Starting Address -192.168.1.2
IP Pool Ending Address - 192.168.1.199
"Asus Log snippet"
Apr 21 17:46:35 DSL-AC88U daemon.info dhcpd: DHCPDISCOVER from 38:22:e2:26:2b:43 via br0
Apr 21 17:46:36 DSL-AC88U daemon.info dhcpd: DHCPOFFER on 192.168.1.190 to 38:22:e2:26:2b:43 (DESKTOP-1D0F45C) via br0
Apr 21 17:46:38 DSL-AC88U daemon.info dhcpd: DHCPREQUEST for 192.168.1.232 (192.168.1.200) from 38:22:e2:26:2b:43 via br0: unknown lease 192.168.1.232.
Apr 21 17:46:38 DSL-AC88U daemon.info dhcpd: DHCPNAK on 192.168.1.232 to 38:22:e2:26:2b:43 via br0
Apr 21 17:46:38 DSL-AC88U daemon.info dhcpd: DHCPDISCOVER from 38:22:e2:26:2b:43 (DESKTOP-1D0F45C) via br0
Apr 21 17:46:38 DSL-AC88U daemon.info dhcpd: DHCPOFFER on 192.168.1.190 to 38:22:e2:26:2b:43 (DESKTOP-1D0F45C) via br0
Apr 21 17:46:38 DSL-AC88U daemon.warn miniupnpd[3026]: SSDP packet sender 169.254.58.61:58096 not from a LAN, ignoring
Apr 21 17:46:39 DSL-AC88U daemon.info dhcpd: Reclaiming not used lease 192.168.1.190.
Apr 21 17:46:39 DSL-AC88U daemon.info dhcpd: DHCPREQUEST for 192.168.1.190 (192.168.1.1) from 38:22:e2:26:2b:43 (DESKTOP-1D0F45C) via br0
Apr 21 17:46:39 DSL-AC88U daemon.info dhcpd: DHCPACK on 192.168.1.190 to 38:22:e2:26:2b:43 (DESKTOP-1D0F45C) via br0
Apr 21 17:46:39 DSL-AC88U daemon.info dhcpd: DHCPDISCOVER from 38:22:e2:26:2b:43 (DESKTOP-1D0F45C) via br0
Apr 21 17:46:39 DSL-AC88U daemon.info dhcpd: DHCPOFFER on 192.168.1.190 to 38:22:e2:26:2b:43 (DESKTOP-1D0F45C) via br0
Apr 21 17:46:39 DSL-AC88U daemon.warn miniupnpd[3026]: SSDP packet sender 169.254.58.61:58096 not from a LAN, ignoring
Apr 21 17:46:40 DSL-AC88U daemon.info dhcpd: Reclaiming not used lease 192.168.1.190.
Apr 21 17:46:40 DSL-AC88U daemon.info dhcpd: DHCPREQUEST for 192.168.1.190 (192.168.1.1) from 38:22:e2:26:2b:43 (DESKTOP-1D0F45C) via br0
Apr 21 17:46:40 DSL-AC88U daemon.info dhcpd: DHCPACK on 192.168.1.190 to 38:22:e2:26:2b:43 (DESKTOP-1D0F45C) via br0
Apr 21 17:48:12 DSL-AC88U daemon.info dhclient: XMT: Solicit on eth0.0, interval 125660ms.
Apr 21 17:50:19 DSL-AC88U daemon.info dhclient: XMT: Solicit on eth0.0, interval 126340ms.
Apr 21 18:00:01 DSL-AC88U daemon.info dhcpd: DHCPREQUEST for 192.168.1.227 from 40:ec:99:6d:e7:55 via br0: unknown lease 192.168.1.227.
Apr 21 18:00:01 DSL-AC88U daemon.info dhcpd: DHCPNAK on 192.168.1.227 to 40:ec:99:6d:e7:55 via br0
Apr 21 18:00:01 DSL-AC88U daemon.info dhcpd: DHCPDISCOVER from 40:ec:99:6d:e7:55 (DESKTOP-1D0F45C) via br0
Apr 21 18:00:01 DSL-AC88U daemon.info dhcpd: DHCPOFFER on 192.168.1.5 to 40:ec:99:6d:e7:55 (DESKTOP-1D0F45C) via br0
Apr 21 18:00:01 DSL-AC88U daemon.info dhcpd: DHCPREQUEST for 192.168.1.227 (192.168.1.200) from 40:ec:99:6d:e7:55 via br0: unknown lease 192.168.1.227.
Apr 21 18:00:02 DSL-AC88U daemon.info dhcpd: Reclaiming not used lease 192.168.1.5.
Apr 21 18:00:02 DSL-AC88U daemon.info dhcpd: DHCPREQUEST for 192.168.1.5 (192.168.1.1) from 40:ec:99:6d:e7:55 (DESKTOP-1D0F45C) via br0
Apr 21 18:00:02 DSL-AC88U daemon.info dhcpd: DHCPACK on 192.168.1.5 to 40:ec:99:6d:e7:55 (DESKTOP-1D0F45C) via br0
Apr 21 18:00:02 DSL-AC88U daemon.info dhcpd: DHCPDISCOVER from 40:ec:99:6d:e7:55 (DESKTOP-1D0F45C) via br0
Apr 21 18:00:02 DSL-AC88U daemon.info dhcpd: DHCPOFFER on 192.168.1.5 to 40:ec:99:6d:e7:55 (DESKTOP-1D0F45C) via br0
Apr 21 18:00:02 DSL-AC88U daemon.info dhcpd: DHCPREQUEST for 192.168.1.227 (192.168.1.200) from 40:ec:99:6d:e7:55 via br0: unknown lease 192.168.1.227.
Apr 21 18:00:02 DSL-AC88U daemon.info dhcpd: DHCPNAK on 192.168.1.227 to 40:ec:99:6d:e7:55 via br0
Apr 21 18:00:08 DSL-AC88U daemon.info dhclient: XMT: Solicit on eth0.0, interval 111010ms.
Apr 21 18:00:21 DSL-AC88U daemon.info dhcpd: DHCPREQUEST for 192.168.1.227 from 40:ec:99:6d:e7:55 via br0: unknown lease 192.168.1.227.
Apr 21 18:00:21 DSL-AC88U daemon.info dhcpd: DHCPNAK on 192.168.1.227 to 40:ec:99:6d:e7:55 via br0
Apr 21 18:00:21 DSL-AC88U daemon.info dhcpd: DHCPDISCOVER from 40:ec:99:6d:e7:55 (DESKTOP-1D0F45C) via br0
Apr 21 18:00:21 DSL-AC88U daemon.info dhcpd: DHCPOFFER on 192.168.1.5 to 40:ec:99:6d:e7:55 (DESKTOP-1D0F45C) via br0
Apr 21 18:00:21 DSL-AC88U daemon.info dhcpd: DHCPREQUEST for 192.168.1.227 (192.168.1.200) from 40:ec:99:6d:e7:55 via br0: unknown lease 192.168.1.227.
The OUTBUILDING (ZYXEL) Router has the following settings:
IP Address - 192.168.1.200
IP Address Range 192.168.1.201 ~ 192.168.1.254
Zyxel Router snippet (No Idea why the date and time is wrong but this is for the same time period as above:
43Nov 25 22:54:06daemondebugdhcpddnsmasq-dhcp: sendLeaseMessageToESMD send to esmd buf = {\"ac\":\"add\",\"expire\":\"773663\",\"mac\":\"40:ec:99:6d:e7:55\",\"ip\":\"192.168.1.227\",\"host\":\"DESKTOP-1D0F45C\",\"vendor\":\"MSFT 5.0\",\"moui\":\"*\",\"serial\":\"*\",\"pclass\":\"*\",\"cid\":\"01:40:ec:99:6d:e7:55\",\"ifname\":\"br0\"}
44Nov 25 22:54:06daemoninfodhcpddnsmasq-dhcp: sendLeaseMessageToESMD
45Nov 25 22:53:56daemoninfodhcpddnsmasq-dhcp: DHCPNAK(br0) 192.168.1.5 40:ec:99:6d:e7:55 wrong server-ID
46Nov 25 22:53:52daemoninfodhcpddnsmasq-dhcp: DHCPNAK(br0) 192.168.1.5 40:ec:99:6d:e7:55 address not available
47Nov 25 22:51:58usernoticeupnpzupnp: upnp: NOTIFY
48Nov 25 22:51:58usernoticeupnpzupnp: upnp: ssdp:alive
49Nov 25 22:51:58usernoticeupnpzupnp: upnp: NOTIFY
50Nov 25 22:51:58usernoticeupnpzupnp: upnp: NOTIFY
51Nov 25 22:51:58usernoticeupnpzupnp: upnp: NOTIFY
52Nov 25 22:51:58usernoticeupnpzupnp: upnp: ssdp:alive
53Nov 25 22:51:58usernoticeupnpzupnp: upnp: NOTIFY
54Nov 25 22:51:58usernoticeupnpzupnp: upnp: ssdp:alive
55Nov 25 22:51:58usernoticeupnpzupnp: upnp: NOTIFY
56Nov 25 22:51:57usernoticeupnpzupnp: upnp: NOTIFY
57Nov 25 22:51:57usernoticeupnpzupnp: upnp: NOTIFY
58Nov 25 22:51:57usernoticeupnpzupnp: upnp: ssdp:alive
59Nov 25 22:51:57usernoticeupnpzupnp: upnp: NOTIFY
60Nov 25 22:51:57usernoticeupnpzupnp: upnp: ssdp:alive
61Nov 25 22:51:57usernoticeupnpzupnp: upnp: NOTIFY
62Nov 25 22:51:57usernoticeupnpzupnp: upnp: NOTIFY
63Nov 25 22:51:57usernoticeupnpzupnp: upnp: NOTIFY
64Nov 25 22:51:57usernoticeupnpzupnp: upnp: ssdp:alive
65Nov 25 22:51:24userinfohttpdzHttpd: Account: User 'admin' login from the host(192.168.1.5).
66Nov 25 22:49:31daemoninfodhcpddnsmasq-dhcp: DHCPNAK(br0) 192.168.1.5 40:ec:99:6d:e7:55 wrong server-ID
67Nov 25 22:49:27daemoninfodhcpddnsmasq-dhcp: DHCPNAK(br0) 192.168.1.5 40:ec:99:6d:e7:55 address not available
What am I doing wrong? Any advice appreciated (sorry if its obvious im a newbie to home networks!)
Reset the second router to factory defaults. Does it have AP mode? If so, use that. Do so by connecting a cable from the main Router's LAN ports to the WAN port of the second router (AP).
Running second DHCP server on what you need to be an Access Point only. If this Zyxel router has no Access Point mode available - disable DHCP, NAT, UPnP on it, use LAN port for connection to your main router, ser LAN IP in main router's subnet in or out of DHCP range, set DNS/Gateway to main router's LAN IP. The goal is to turn the Zyxel into wired-to-wireless bridge only, no routing. Try again. If not possible on this model - get a proper Access Point.
This worked perfectly! I forgot to turn off DHCP on the 2nd router!.
Thanks so much All!
