x3mRouting help me Please, x3mRouting Selective Routing installation failed
worf
I cannot install x3mRouting via amtm on ASUS RT-AC86U.
firmware version:merlin 384.19
Thanks.
Thanks.
That error message is from amtm. You need to have a USB plugged in and formatted as ext2, ext3 or ext4 with entware installed. amtm has the option to format the USB and install entware. If you still have issues, let me know. Or, try installing without amtm by copying and pasting the command below into an SSH session:
sh -c "$(curl -sL https://raw.githubusercontent.com/Xentrk/x3mRouting/master/Install_x3mRouting.sh)"
x3mRouting README
x3mRouting README
Hi, Xentrk:
Thank you for your answer。 I have installed entware and formatted the USB as ext4, please see the screenshot
I found the reason. Because the terminal cannot connect to raw.githubusercontent.com
curl: (7) Failed to connect to raw.githubusercontent.com port 443: Connection refused
You are being blocked. Either a firewall setting or the ip you are connected to (geo location) is my guess. Can you access github in a browser?
Readme Page
https://github.com/Xentrk/x3mRouting
Raw Installation Source Code
Readme Page
Thanks, I have already installed it. Please take a look at this ticket https://www.snbforums.com/threads/x3mrouting-failed-to-configure-based-on-vpn-client-routing.69391/
