help setting up VPN to use a gateway from my office
Din Covo
Hi all,
I have a 66U at my office with the latest merlin on it , i used to have another 66U at home with a VPN set up between the two (Server at workplace), to the 66U at home i have a simple router connected by cable and it was set with static ip address from the pool of my office(Through the vpn, using a gateway from the office as well), that allowed me to connect to a different ISP from what i have in my house through the office.
Sadly the 66U at the house died last week and i bought a 56S without know its not supported by merlin.
first it took some quite time i could set an openvpn connection because of the settings in the server required an open vpn 2.4 which is not supported by the 56S.
Now i do have the VPN running but it does not work the way it did before, i cannot just set my secondary router as if its part of the LAN and leech internet from the office's gateway.
DHCP on the the 66U & 56S as there is a DHCP running on my server, previously it would just assign any computer connecting to the LAN at the office but it just doesnt work anymore.
Here are the settings i use for the server:
would appreciate any help...
