help with enstation 5-AC
PRoseFarm
Newbie here - trying to set up a wireless bridge using enstation 5-AC using Windows 10. "Before you start!" you are supposed to go into your network connections and click on Local Area Connection to change the IP address. Problem is, when I go there I don't have an icon for Local Area Connection. Only Ethernet/unidentified network and my wifi and bluetooth. I did use the ethernet icon and changed IP address then went into the default 192.168.1.1 page to configure the 2 enstations. Worked ok but then ran into a dead end where the page would no longer load and now the default page (192.168.1.1) won't load, nor will anything load using any of the other IP addresses I used. Hearing crickets while I'm waiting for engenius tech support to get back with me... In the meantime, any help out there? Or how can I find someone locally to look at this and help me with this? What kind of business would I search for? Thanks in advance...
Where are you what country and state?
