Help with openvpn server and asus ddns
ryancharles
I have an n56u with a qnap TS-121p NAS. I setup openvpn on the NAS, inserted my public ip (174.x.x.x) in my config file, added my port forward rule to my NAS and voila, everything is working.
then I wanted to enable and setup ddns for when my public ip changes. I decided to use the asus DDNS service. Logged into the router, navigated to the DDNS tab, registered my name and I got the message that mydomain.asuscomm.com should now resolve to my public router ip.
I noticed that on the front page there's a yellow outlined exclamation mark next to my DDNS name mydomain.asuscomm.com. When I used nslookup to lookup mydomain.asuscomm.com it does not resolve to 174.*.*.*. It resolved to 217.162.*.* I Replaced the public ip with mydomain.asuscomm.com in my openvpn config file and due to the incorrect resolution my vpn is no longer connecting.
Am I missing something? Any help would be appreciated.
Did you try a reboot of the router?
Check the System Log, and see if there's a more specific error in there regarding ez-ipupdate.
Ok...I here's the system log from the gui....
Jan 8 20:35:40 rc_service: ntp 361:notify_rc restart_upnp
Jan 8 20:56:11 rc_service: httpd 283:notify_rc start_webs_update
Jan 8 20:59:12 rc_service: httpd 283:notify_rc restart_ddns
Jan 8 20:59:12 ddns: clear ddns cache file for server/hostname change
Jan 8 20:59:12 ddns update: ez-ipupdate: starting...
Jan 8 20:59:12 ddns update: connected to ns1.asuscomm.com (103.10.4.108) on port 80.
Jan 8 20:59:15 ddns update: Asus update entry:: return: HTTP/1.1 203 |mydomain.asuscomm.com|mydomain1112.asuscomm.com^M Date: Thu, 09 Jan 2014 01:44:06 GMT^M Server: Apache/2.4.3 (Unix) PHP/5.4.14^M X-Powered-By: PHP/5.4.14^M Content-Length: 0^M Content-Type: text/html^M ^M
Jan 8 20:59:15 ddns update: retval= 1, ddns_return_code (,203)
Jan 8 20:59:15 ddns update: asusddns_update: 1
interesting..not sure why 1112 would have be appended to the name. still not working though
Have you tried changing your domain name to something else? I had this happened to me when I switched routers, from N66u to AC66u and tried using the same ddns domain name with asus ddns service, had to registered another name in order for it to work - now I can access my network from outside (external IP)
