High CPU
clvk07
Hi It seems that the AC88U has high CPU since the upgrade to 384.7 (and 72).
21374 1 admin R 1500 0.2 0 49.6 /usr/sbin/acsd
this process shows always 50% of cpu and in the asus screen core 1 or core 2 reach 100% at any given time. How can I identify what is causing this?
If you are running Merlin, install Entware and then open a SSH terminal and install htop.
Run htop. It's a command line resource monitor.
Sent from my SM-G965F using Tapatalk
If you are using auto channel selection on either band, try setting both to a fixed channel.
installed HTOP but seems to give same info as TOP.....
Only running 2.4GHZ band. usually if I kill the process or reboot the rooter it fixes the problem. (until it happens again).
I guess there is no way to know who is using /usr/sbin/acsd?
acsd = Auto Channel Selection Daemon...the wireless.....
You might try turning off all your wireless clients, then turning them back on one by one to see if it's a specific client causing problems.
Get It now.... will try that next time if happens
@clvk07
I'm just thinking out loud....do you have any clients that were bought in or are set to a different region from your router? Is your router operating in a different region from where it was purchased?
I'm getting this issue now with Merlin 384.15. CPU running hot with acsd.
Just default wireless settings.
Sent from my SM-G977B using Tapatalk
ACSD is used to scan and select low-interference channels, so if SMART-connect is on and/or auto-channel is selected then setting a fixed channel for each frequency band may alleviate the issue (a cell phone Wi-Fi Analyzer app can help identify the least congested channel). A client, such as a new phone (or older smart-tv), is a more likely culprit than a remote attack.
