HomePlug Blocking Device
HarryMuscle
Is there a device that can be installed that would completely block a HomePlug network from propagating? Searching for HomePlug filters just comes up with filters to filter out noise not to filter out the actual signal.
Thanks,
Harry
Not really sure what you are asking here. More information is definitely needed if you want a better answer.
If I am guessing correctly, you have 2 devices and want to block additional devices from being added? If so, depending on the brand, model and firmware version, there should be security within the device or software to restrict this. Although, with physical access all you have to do is press a button on one of the existing devices to add a new one to the network.
