How to change /opt path
demokedes
Dear all,
I am changing external usb storage. Consequently I have to change /opt path. What is the easiest way to achieve that?
I moved content of the old location to the new location.
The old location is not accessible anymore. If I cd /opt, I get:
Bash:
admin@RT-AX88U-CD00:/jffs/scripts# cd /opt
-sh: cd: can't cd to /opt
/opt is a link to /tmp/opt. This in turn is a link to the real entware directory on the USB drive. This link is created automatically by the Entware startup process.
Colin,
Thank you understand that. But is it possible to manually change the path? I moved the directory to another location. If I run the command from the new location it is working. Can this be done manually or do I need to reinstall entware?
Sorry, I don't understand what your problem is if it's working now. Everything in Entware is compiled to work from /opt therefore your new location must be soft linked to /opt. The Entware startup process usually does this, so if you've moved Entware to a different USB drive it will automatically be picked up.
If you installed Entware via amtm or Diversion the startup process will scan the USB drive when it's mounted looking for /entware*/bin/opkg. It will use this as the Entware location if it finds it.
Not sure if this will help, but here's a script I wrote that gets activated by the nvram variable script_usbmount=path-to-script which is present in both the stock asuswrt and asuswrt-merlin. The script runs when a usb stick gets successfully mounted. To make sure that the path is available shortly after boot, I put the script, executables and libraries in /jffs. The section on handling /tmp/opt might give some hints.
#!/bin/sh
  echo "=== $0 == $( /bin/date ) ==="
  export PATH=/bin:/sbin:/usr/bin:/usr/sbin:/jffs/bin
  export LD_LIBRARY_PATH=/jffs/lib:$LD_LIBRARY_PATH
  # Do an fsck just in case.
  /bin/umount /dev/sda1
  /jffs/bin/fsck.ext4 -fpv /dev/sda1
  # Since there's a fixed read-only symlink of /opt->/tmp/opt, cut
  # out the additional redirect symlink of /tmp/opt->/tmp/mnt/sda1.
  /bin/mkdir -p /tmp/opt
  /bin/mount /dev/sda1 /tmp/opt
  /sbin/swapon /dev/sda2
  # Get my basics into the root home directory.
  cd /tmp/opt/usr/
  /bin/cp -pr .config .profile .ssh .vimrc bin /root/
  cd /root/
  /bin/chmod -R og=,u+rwX .ssh
  # Start a script that creates a SOCKS5 proxy and a lighttpd
  # instance with a common home page for all my devices.
  ( /usr/bin/nohup /jffs/bin/fix_srvcs </dev/null >/dev/null 2>&1 & ) </dev/null >/dev/null 2>&1 &
  echo "=== $( /bin/date ) ==="
} >/tmp/usb_mount.log 2>&1
Dear all,
Bash:
If you use amtm or Diversion to setup Entware then the scenario is simple and works 100% of the time - unless someone tinkers with things or changes the file content that my scripts use.
amtm and Diversion start Entware services with /jffs/scripts/addons/diversion/mount-entware.div
If Diversion is installed, the file has additional content but the logic is the same:
While the routers is mounting an attached storage device, mount-entware.div will first look for /entware/bin/opkg.
amtm and Diversion create and install Entware into a folder named entware on the selected device, this is the default.
However, older scripts created a variation of that folder name like entware-ng - including my scripts a long time ago.
So, if there is no entware folder, mount-entware.div then looks for /entware*/bin/opkg and would rename it to entware if its a variation of entware*.
All actions when mount-entware.div is triggered are logged to the routers Syslog:
When Diversion is installed:
Diversion: Starting Entware and Diversion services on <device>
Without Diversion:
Entware: Starting Entware services on <device>
It also states if there are two instances of Entware found on separate devices.
So in essence, check your Syslog after a reboot to find out why your new device is not starting Entware on your router.
I am not using Diversion, so I am not familiar with it.
During the weekend, I was testing a bit and I solved it.
I added following to lines into init-start script and it is working now.
Thank you!
Bash:
/bin/mount /tmp/mnt/Verbatim/sdb1/entware /tmp/opt
But this script has a problem in my environment, because I have to USB stick /dev/sdc1 /dev/sdc2. ENTWARE is mounted on /dev/sdc1 but I do a full backup of ENTWARE on ENTWARE_BKUP on /dev/sdc2. Now unfortunately the amtm script mount under /opt the sdc2 i.e ENTWARE_BKUP which is something I don't want. How can we fix that? Is there some option in amtm to avoid this odd behavior?
Without Diversion:
If you rename the opkg binary file in /entware/bin/ on the backup partition to have a different name (e.g. add .bkp), then it won’t see Entware as being available to mount. I don’t know how that would work for your backup strategy, however.
If I understand correctly, you have two USB devices plugged into your router. One is labeled ENTWARE and the other ENTWARE_BKUP.
So far so good.
ENTWARE_BKUP contains a mirror backup from the ENTWARE device, correct?
If so, ENTWARE_BKUP contains a folder called entware, just as the device ENTWARE does?
If so, there's your problem.
amtm looks for exactly this folder, specifically the file /entware/bin/opkg to determine if it is a valid Entware installation.
It does this for every device the router detects while booting or mounting USB devices.
amtm mounts the first valid Entware installation found on a device. In your case it seems device ENTWARE_BKUP is usually mounted first.
Now, there is no way to change the order it mounts devices as this is Asus code.
With that explained your option is to rename the entware folder on the ENTWARE_BKUP device to something like backup_entware.
DO NOT rename it to entware_backup as amtm would rename any folder that starts with entware* and contains a valid Entware installation.
Hi TLC,
thanks a lot for your feedback. You got perfectly my situation. What you described makes sense to me too. I was using currently a hack in post-mount removing the /tmp/opt symbolic link and creating a symbolic link /tmp/opt to /tmp/mnt/ENTWARE/entware. But I like more your solution, also because I can easily change the name of entware dir in ENTWARE_BKUP disk to backup_entware; it's not a problem for me because it is just a backup. I tried your fix and it is working perfectly!
Thanks a lot again.
Yes, thanks, that options should work as well, but I already used the solution from TLC which is perfectly working too. Thanks a lot.
