How to configure Router RT-AC87U with Cyberghost OpenVPN
waterman1000
Hi all
couldn't find any info on how to do this, but eventually managed to get it to work.
once you've logged into your Cyberghost account & gone to my devices, scroll to the bottom of the page & select
1 - Openvpn UDP for your protocol (this is faster than TCP)
2 - select your desired country.
3 - then click on "download configuration.
4 - unzip the download to a folder on your computer & you should have four files. ca-crt/client.crt/client.key & openvpn.ovpn. (make sure that all four files open with notepad)
5 - on your router click the VPN tab then VPN client tab, then click add profile.
6 - description, whatever you want to call it. Then enter your username & password from Cyberghost my device web page. locate the file openvpn.ovpn & click upload. (you will get an error of, lack of client key/lack of client certificate & lack of certificate authority)
7 - Tick import the CA file or edit the ovpn file manually.
8 - click edit manually
9 - copy & paste ca-crt file into the certifcate authority box
10 - copy & paste client.crt into the client certificate box
11 - copy & paste client.key into client key box
12 - leave static key & certificate revocation boxes empty.
13 - click save
14 - click connect
hopefully you should now be connected (it might take a minute or so)
Hope this helps Waterman.
