How to delete wireguard client
Dutchmike64
I cannot find a way to delete a wireguard client.
On the openvpn client page there is a "Default" button that will delete/reset the entry but no such thing on the wireguard page
On VPN director there is also no delete button
I tried zeroing all the fields but that doesn't work too.
Thanks !
I am staring at the screen as best as i can but i can't find anything :
(Running 388 on a tuf-ax5400)
You can't. There are so few settings associated to it that it wasn't worth implementing. Just don't enable that client.
The blank config file worked like a charm for me too. But yes, as pointed out above, funnily logged me out of the router immediately after uploading.
Has anyone been able to get ProtonVPN WireGuard client to work on Asus RT-AX86U pro with Merlin 388.1? Please assist. Thamks
