How to reroute traffic?
Pergola Fabio
Hey, got a question, i have a client on my local lan, lets say a client with IP 192.168.0.50
that clients connects to an public service online, lets say on : 55.66.77.88 port 5678
how can i modify the traffic, so the router reroutes all traffic to an internal local device instead? i have the same services running on a local ip , lets say 192.168.0.51:5678
so in other words, i want all outgoing traffic from 192.168.0.50 to 55.77.77.88:5678 rerouted to 192.168.0.51:5678 , so it never reaches that public ip....
is there a way to configure that? i'm running merlin, do i need merlin?
thnx in advance
With Merlin you could create a nat-start script that contains the following line:
iptables -t nat -I PREROUTING -s 192.168.0.50 -d 55.66.77.88 -p tcp --dport 5678 -j DNAT --to-destination 192.168.0.51
yes, its all ipv4
thnx for all info, was just reading how to use scripts :
gonna start first without it, and test
btw, for testing, how do you delete that rule? is there an easy way?
i was reading this guide : https://www.digitalocean.com/community/tutorials/how-to-list-and-delete-iptables-firewall-rules
i first need to show all iptables line numbers with example :
iptables -L --line-numbers
than delete the specific one, i think your example will be an OUTPUT chain, right?
then delete the specific line, probably the first one, with :
iptables -D OUTPUT 1
correct?
Just issue the same command again but replace "-I" with "-D".
correct?
That won't work unless you specify the nat table (-t nat). The chain is PREROUTING not OUTPUT.
can i also use a DNS instead? like www.123.com instead of 55.66.77.88 ?
Depends on the exact use case as to whether DNS would be helpful. Do you want this rule to apply to everyone on the LAN or only a specific client?
One other consideration - you don't mention whether you're using DHCP or static IP assignment for the client. Best option would probably be manual/fixed assignment under the router DHCP settings - keeps any iptables scripts simpler while still leaving the router (and wider network) better able to track things like hostname/IP mapping.
perfect
yes, the local device has a fixed IP
seems dns is not possible :
but actually, that doesnt mather, that local 192.168.0.50 device is only connecting to cloud , only on port 5678 , so do i need to specify that www.123..com / 55.66.77.88 at all? maybe i can drop it?
so instead of :
it will be like:
iptables -t nat -I PREROUTING -s 192.168.0.50 -p tcp --dport 5678 -j DNAT --to-destination 192.168.0.51
so i remove the "-d 55.66.77.88" completely? is that valid?
I think you're making the same mistake that I first did when reading the question. He's not asking to change a DNS reply but whether he can substitute a DNS name for the IP address in the iptables command.
Yes it is possible. I tried it myself. That example is attempting something different. Unless I'm misunderstanding what you're trying to use DNS for.
I missed the port element - DNS to redirect all requests would work (albeit also affecting the local instance of the service which, depending what it is, could still need external access) but in this case the ask is only to redirect traffic destined to a single port. Doh!
perfect
then i can use :
iptables -t nat -I PREROUTING -s 192.168.0.50 -d www.123.com -p tcp --dport 5678 -j DNAT --to-destination 192.168.0.51
if that works, thats good enough for me..
using a DNS there is bether, i dont know if that cloud service using multiple ip's for that www.123..com site, this command should resolve that
thnx for all feedback!!
perfect, it works!! =-)
is there a way to actually see the route in the ipables?
if i do like :
iptables -L
i see a lot of chains, but not the PREROUTING chain?
thnx !
You need to specify the nat table (-t nat).
iptables -t nat -L -v
or
iptables -t nat -L -vn
or
iptables-save -t nat
P.S. It's a rule not a route.
ok, that works!
lets say, created the rule witth this at destination: --to-destination 192.168.0.51
is there a failsafe? let me explain, if 192.168.0.51 is not avaible on my system for whatever reason, can i route it back to the original : www.123.com ?
ok, that works!
You'd have to setup some sort of monitoring script that periodically checked whether 92.168.0.51 was down and if so delete the iptables rule. Depending on your use case that might be more hassle than it's worth.
