How to setup LAN instead of broken WAN port
dragon31337
I have an AC66u ASUS router running latest merlins build.
Unfotuntaley my WAN port does not work anymore. Is there a way to setup one of LAN ports as a WAN port? How to do that properly to make it transparent for the WebUI and so on.
Lets say we virtually assign WAN to LAN1 and WAN become a LAN1 port which will not work because of it is broken, but we do not care about it as long as we have 3 other LAN ports.
Thanks in advance for anything useful on this topic.
What is Dual WAN configuration? I'm not seeing such option in the webUI.
I'm ok with SSH, but I do not know commands i should use.
Dual WAN is only available in the experimental releases, as this is a work-in-progress feature that Asus is still working on.
Can you recommend some particular build to try? I'd like to be a beta tester, Merlin =)
The latest non-beta experimental build should be fine.
I don't make experimental builds of beta releases.
