I want to enable guest bandwidth limiter but leave adaptive qos, is this possible?
fearz
I thought guest network have a separate bandwidth limiter but not the case with latest merlins build..if thats the case are these any workarounds for it?
Sent from my iPhone using Tapatalk Pro
Well initially i wanted to enable both qos and bandwidth limiter to limit some devices then i learned that on recent firmware guest bandwidth limiter is a new feature so I thought it may work with qos.
Is there any way even via shell to limit bandwidth speed for only 1 device while keeping qos enabled?
yes, in parental control
