My bad, not to explain it very wellI think the answer is in the text in the header of your first screenshot.
Furthermore: doesn’t your VPN provider provide ready-made .ovpn config files? I can just download them from the website of my VPN provider, I’ve never had to ‘create’ my own .ovpn config file.
Yes, but it seems that my former VPN provider was still there after the reset.Did you reset the VPN client before uploading the new configuration file? Default button at the bottom of the page.
The first screenshot just shows nothing, whereas I thought my "tls-crypt" would have been placed there,
as shown in the "Static Key.txt".
Only paste the content of the ----- BEGIN xxx ----- / ----- END xxx ----- block (including those two lines)
-----BEGIN OpenVPN Static key V1-----
a1198ef649f1c23861a2a19f2c6b27aa
5e43be761e0c71e9c2e8d33b75af289e
-----END OpenVPN Static key V1-----
Yes, you're right.I meant, the header says:
So I guess the key should be pasted without the proceeding <tls-crypt> and the ending </tls-crypt>, so like
Code:-----BEGIN OpenVPN Static key V1----- .... a1198ef649f1c23861a2a19f2c6b27aa 5e43be761e0c71e9c2e8d33b75af289e .... -----END OpenVPN Static key V1-----
Yes, you're right.
I have tried to copy/paste all four certs and then save all of them, but it seem that data in the Static Key
always disapear (removed=blanks). Seems strange to me !! Maybe a bug ??
----- BEGIN xxx ----- (contents of static key / certificates with BEGIN and END tags included ----- END xxx ----- ?I have tried to copy/paste all four certs and then save all of them
After you hit save where you enter the certs, did you also hit 'Apply' at the bottom of the page?I have tried to copy/paste all four certs and then save all of them,
First I appriciate your help, thanks.Have you tried to paste the keys without the surrounding <tls-crypt> tags as the header suggests, just from----- BEGIN xxx -----(contents of static key / certificates with BEGIN and END tags included----- END xxx -----?
Haven't heard anyone else reporting this, so a bug seems unlikely to me. When I import and .ovpn config the certificates are included, I don't have to paste them manually. They are imported with the .ovpn config (and present in the config file). Most of the time I don't even look at it, as I know they're imported with the rest of the config. Have you opened the .ovpn config with a text editor like Notepad++ and checked whether the certificates aren't already included in the config? Or else, maybe your VPN provider has a step by step guide how to configure their VPN on Asuswrt(-Merlin), like my VPN Provider has? There are also several general guides on how to configure a VPN client on Asuswrt-Merlin.
I was wondering about tls-crypt and as far as I'm aware it should be supported by the included version of OpenVPN (I read it was included in 2.4.x and if I'm not mistaking 2.5.2 is the current version) and as your VPN-provider provides these configs, they should support it too (why else include it, instead of only tls-auth).
Question for @RMerlin: is the use of tls-crypt fully supported on 386.2_4?
Otherwise, I'm out of ideas. Maybe @eibgrad can help you out, he knows an awful lot about VPNs, way more compared to my rookie knowledge.
Indeed YESAfter you hit save where you enter the certs, did you also hit 'Apply' at the bottom of the page?
Right. Downloaded from my VPN provider. The script includes "tld-crypt" (and CA, CERT and Key). When I import the script, the "tld-crypt" doesn't get imported. After the import I try to start VPN in the router, but the router gets stuck, with a yellow msg. "Connection ...." and never starts.I'm not following you, sorry. You have one configuration .ovpn file to import. The file you have downloaded from your new VPN provider.
If you look in your logfiles (System Log > General Log) you will most like see a TLS authentication error, while it tries to connect, because the last key doesn't get imported, so it can't establish a secure control channel. Please post your syslog (without any private info) to a site like pastebin or an alternative so we can see if we can find clues why a. the key won't get accepted and b. your connection can't be established (which is most likely answered by a.)Right. Downloaded from my VPN provider. The script includes "tld-crypt" (and CA, CERT and Key). When I import the script, the "tld-crypt" doesn't get imported. After the import I try to start VPN in the router, but the router gets stuck, with a yellow msg. "Connection ...." and never starts.
Attached is the log file from the router (RT-AX88U) Merlin 368.2_4 ...So, it's just the last key in your .ovpn config that doesn't 'stick'? That one doesn't get saved?
Any clues in your system logfile why it refuses to save that tls-crypt key?
ovpn-client1[14946]: TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
ovpn-client1[14946]: TLS Error: TLS handshake failed
ovpn-client1[14946]: SIGUSR1[soft,tls-error] received, process restarting
ovpn-client1[14946]: Restart pause, 5 second(s)
ovpn-client1[14946]: NOTE: the current --script-security setting may allow this configuration to call user-defined scripts
Ok, here are some errors. Seems that jfss2 (GC) is full. Could that be my problem ??This is only from the attempt to connect. Here's the error I expected:
Code:ovpn-client1[14946]: TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity) ovpn-client1[14946]: TLS Error: TLS handshake failed ovpn-client1[14946]: SIGUSR1[soft,tls-error] received, process restarting ovpn-client1[14946]: Restart pause, 5 second(s) ovpn-client1[14946]: NOTE: the current --script-security setting may allow this configuration to call user-defined scripts
which means there is a misconfiguration regarding TLS (ie. your missing key) why it can't setup a secure connection.
Is there anything in your logfile when importing this config, that helps us understand why it doesn't accept the tls-crypt static key? If you can't find it, delete the current config and re-configure it and keep an eye on your logfiles.
Welcome To SNBForums
