Import Client Traffic Rules for OpenVPN Clients?
sone
Hi all,
Is there a way to import "Rules for routing client traffic through the tunnel" with the "Custom Configuration" or a script so I can apply it to the 4 other open client slots without manually adding each one? This is down at the bottom of the OpenVPN Client section (Asuswrt-Merlin 384.8.2)
thanks.
Using the command line on the router you can get the client list information of the first VPN client using:
nvram get vpn_client1_clientlist > CLIENTLIST
This saves the output to a file called CLIENTLIST. You can verify it has worked using:
cat CLIENTLIST
Store the string as a variable... I had problems with long strings in a single command...
CLIENTS="$(cat CLIENTLIST)"
Verify the CLIENTS variable contains the right information
echo $CLIENTS
To copy this to the second clientlist entry:
nvram set vpn_client2_clientlist="$CLIENTS"
(don't forget the quotes)
remove the CLIENTLIST file (you don't need it):
rm CLIENTLIST
NOTE - When I've done this, I've chosen to capture the output in a file and then use the CLIENTS variable as I had unexpected results with large clientlists.
Oh sweet!! Thank you so so much! This will save me a ton of time every time I switch/add new OpenVPN clients.
