Improvement to web gui of the router
Mistermoonlight
A big improvement in many differents menu of the RT-N66U 3.0.0.4.270.24 web gui menu would be to allow to edit settings, and not just add/remove them.
These limitations can be seen in the "Network filter menu", "port fowarding", "port trigger", "url filter", "keywork filter" menus, and many others. I have seen much much lower cost routers where we can edit rules instead of removing/adding them. I have seen also other routers where we can enable/disable a rule instead of recreate it each time it is needed. This would make the router much more powerful and user friendly to use
The delete/add process needed to change a rule or other settings reminds me unexperience programmer who designed a gui, without ever using it.
This would make a definitly better user interface of what appears under the hood a very good router.
Common Asus, listen carefully to customers ;)
J I can't reset or access ASUS TUF-AX6000 GUI ASUS N Routers & Adapters 8
