Hello,
I am having serious problems with my new RT-AC86U currently running Merlin 384.8 beta 2.
If my Amcrest NVR1104 is connected directly, the connection drops and reconnects every 10 seconds. If I put a switch in between, it is more stable. However, the wireless connection goes down regularly.
I looked in the log and I see some very strange, see attached partial log file.
My Wifi went down at the same time these strange log messages occurred, and when I unplugged the NVR's network cable from the router, it came back up.
Any ideas what's causing this and how to fix it? I'm happy to provide any additional information, but not sure what will be helpful.
I previously ran an RT-N56U with no problems using this same NVR.
Edit: My 2.4 GHz wireless is not working. It says it's "Channel 0" in the AsusWRT GUI
Edit 2: after these strange problems happen, if I reboot the router, it enters a boot loop where the power lifgt comes on, the Ethernet ports and wan light briefly come on, and then it reboors itself over and over. If I wait several hours and try turning it on again, it's fine, but if I only leave it off for a few mins, it keeps boot looping.
Is this just a defective router?
