Intel Centrino Advanced-N 6200 AGN Card and ASUS RT-N56U
R.Esteves
Hi Guys,
I replaced my Vaio's Wireless Card (Atheros AR9287 2x2 single band) for an Intel Centrino Advanced-N 6200 (2x2 dual band). Now I can't connect at 300mbps to my router (Asus RT-N56U 2x2 dual band) not in 2,4ghz nor 5ghz. It actually connects at 300mbps but after 1 or 2 seconds it drops to 150mbps and stay there.
All configuration of the network card and the router are correct. N Only, 40mhz, WAP2-Personal, AES, WMM Enabled etc... (tried to change preamble from long to short, enable and disable WMM, and always got the same results: 150mbps at most).
Any ideias to solve that?
Here are images of the card and router config.
91148d1359572394-asus-rt-n56u-router-intel-centrino-advanced-n-6200-agn-card-image.png
91149d1359572425-asus-rt-n56u-router-intel-centrino-advanced-n-6200-agn-card-image-1-.png
91150d1359572472-asus-rt-n56u-router-intel-centrino-advanced-n-6200-agn-card-image-2-.png
91151d1359572473-asus-rt-n56u-router-intel-centrino-advanced-n-6200-agn-card-image-3-.png
Thanks!
Imagens will continue...
