David27
I've using a TUF Gaming AX4200 as my main router and a RT-AC1900U as AiMesh Node.
Yesterday, after the first configuration, AiMesh was working perfectly. Today, coincidently or not, after I made some changes, iPhones can't connect to the node, presenting an error "unable to access (SSID)" or sometimes "invalid password".
The changes I made were enabling DNS over TLS, changed from WPA2 to WPA2 / WPA3-Personal, disabled 11b.
I thought some of this changes could be messing with the Node, so I did a full reset to the node and made e new AiMesh setup. The setup was successful but the problem with the iPhones still remains. I have IoT devices that are able to connect to the Node, just not the iPhones.
Also for some reason, my soundbar is right next to the main router, but keeps connecting to the further away Node, even after disabling Smart Connect.
