IPpv6 with Comcast Business Modems - Ugly
mstrom62
I wanted to write a short piece that may, hopefully save others a wasted day. I use Comcast business internet service, and I have Comcast's SMCD3G-CCR Modem. I use static IP's for my IPv4 implementation, so my choice is limited on what to use form Comcast. Bottom line, IPv6 DHCP-PD does not work on the SMC Modem, From Comcast's forums I understand that the Cisco units also have a failed implementation of DHCP-PD.
That leaves the Netgear CG3000DCR as the only choice that will hand out and route properly a block when it receives a PD request.
So if you are in the same category as me, don't spin your wheels trying to figure out why Merlin's ASUS doesn't work, not a problem in the ASUS. Comcast will be swapping out my Modem on Tuesday, I'll let you know how it goes.
Never been a fan of gateway devices.
Always prefer to go with separate modem and router.
Are you in an area you can not use your own modem/router?
Bridge your modem and let ASUS do the routing. When your modem is in bridge mode, it doesn't do anything else than pass the signal to router, and then it's up to router is IPv6 working or not. I know, because my modem doesn't support IPv6 (TP-Link TD-8810), but IPv6 working fine with RT-N66U.
