IPTABLES to Block Connections
clvk07
Hi
I have a rule to block traffic using IPTABLES
DROP all -- anywhere anywhere
admin@AC88SMB:/tmp/home/root# iptables --list | grep DROP
DROP icmp -- anywhere anywhere icmp echo-request
DROP all -- anywhere anywhere state INVALID
DROP all -- unn-46-234-119-XXX.10gbps.io anywhere
Chain FORWARD (policy DROP)
but it seems that the router still establishes connection:
tcp 192.168.1.41:38965 46.234.119.XXX:25463 ESTABLISHED
any ideas?
Here the full rules. I just added the block using iptables -A INPUT -s IP-ADDRESS -j DROP
everything else is unchanged
Chain INPUT (policy ACCEPT)
target     prot opt source               destination
ACCEPT     udp  --  anywhere             anywhere             udp dpt:4672
ACCEPT     udp  --  anywhere             anywhere             udp dpt:4665
ACCEPT     tcp  --  anywhere             anywhere             tcp dpt:4662
ACCEPT     tcp  --  anywhere             anywhere             tcp dpt:52000
ACCEPT     udp  --  anywhere             anywhere             udp dpt:52000
ACCEPT     all  --  anywhere             anywhere
ACCEPT     udp  --  anywhere             anywhere             udp dpt:1194
ACCEPT     all  --  anywhere             anywhere             state RELATED,ESTA
BLISHED
ACCEPT     all  --  anywhere             anywhere             state NEW
ACCEPT     udp  --  anywhere             anywhere             udp spt:bootps dpt
:bootpc
ACCEPT     tcp  --  anywhere             anywhere             tcp dpt:8082
ACCEPT     tcp  --  anywhere             anywhere             tcp dpt:https
ACCEPT     icmp --  anywhere             anywhere             icmp !echo-request
BLISHED
:bootpc
Chain PControls (0 references)
Chain SECURITY (1 references)
RETURN     tcp  --  anywhere             anywhere             tcpflags: FIN,SYN,
RST,ACK/SYN limit: avg 1/sec burst 5
DROP       tcp  --  anywhere             anywhere             tcpflags: FIN,SYN,
RST,ACK/SYN
RST,ACK/RST limit: avg 1/sec burst 5
RST,ACK/RST
RETURN     icmp --  anywhere             anywhere             icmp echo-request
RETURN     all  --  anywhere             anywhere
Chain logaccept (0 references)
LOG        all  --  anywhere             anywhere             state NEW LOG leve
l warning tcp-sequence tcp-options ip-options prefix "ACCEPT "
There are at least 2 problems.
1) You have added your rule to the end of the INPUT chain. This is pointless as the preceding rule drops everything that has reached that point.
2) If you want to block a client on your LAN you need to use the FORWARD chain (which you haven't shown), not the INPUT chain.
Sorry here the forward chain
is this syntax correct to block: iptables -I FORWARD -d sou.rce.ip.add -j DROP
BLISHED
SECURITY   all  --  anywhere             anywhere
ACCEPT     all  --  anywhere             anywhere             ctstate DNAT
So you want stop one specific client accessing one specific site? You could just do that in the GUI using the Network Services Filter.
iptables -I FORWARD -d <web-address> -s <client-address> -j DROP
this in the command line worked. Thanks. Network filtering services wouldn't work even though the change made was showing up in iptables --list. Only difference is the using the command line it the protocol shows ALL but using network services only UDP or TCP
NSF should work but there are two things to be aware of.
1) NSF doesn't block pings because they are ICMP, not TCP or UDP. But that doesn't matter if all you want to do is block websites (which are TCP).
2) Depending on the firmware you are using you may see an option in NSF to block the protocol "TCP ALL". DO NOT USE THIS. Use "TCP" instead. TCP ALL is a bitmask for the TCP flags - it is not what you want.
Good reminder for everyone!
@RMerlin - I removed this option from my fork. I don't recall seeing you pick that one up....you may want to consider it.
I don't see any reason to remove it. TCP ALL allows you to drop any TCP packet types, which means dropping SYN, ACK, etc...
Doesn't matter if it is TCP or TCP ALL, unless rules is added with the IPTABLE command (which change the block to ALL rather than TCP ) the router Network filtering services (AC88U MERLIN .59) doesn't not seems to block traffic.
Log connection Entry tcp 192.168.1.41:56547 46.234.119.XXX:25463 ESTABLISHED
IPTABLE
DROP tcp -- anywhere unn-46-234-119-XXX.10gbps.io
