SomeWhereOverTheRainBow
Part of the Furniture
are there any firewall rules i can use to block the flow of ipv6 to certain devices?
note this is only to block it on certain devices.
thanks for your response Colin, I am not too familiar with ip6table rules or using mangled options (which i think will work for this type of issue), not like i am with ipv4. I have a specific device on my network I do not want connecting to ipv6 as it seems it is not fully compatible and is causing issues with its functionality. all my other devices run fine on the setup though. I don't know what type of IP6table rule i would need but i do know it would involve using the mac address of the device. Do you know of any sources i could reference maybe? Google has me stumped.Unsolicited incoming traffic is blocked by default. Exceptions can be made under the Firewall tab.
If you want to block traffic that is a response to an outgoing request (a bit like Network Services Filter) then I'd guess you'd have to write some ip6tables rules.
ip6tables -t mangle -A PREROUTING -m mac --mac-source 00:A0:96:CA:F0:F6 -j DROP
Welcome To SNBForums
