[ 3006.102.5 alpha Build(s) ] available build(s)
Do we have an approximate time for when the WiFi 7 models would be ready?
Would 3006.102.5 include the latest drivers for WiFi 7 models that were removed in 3006.102.4?
No ETA, but should be soon, at least for some models. I received some of the missing GPLs today, as well as the wireless drivers that were missing in last week's GPLs.
Awesome! Thanks again for your work!
Several WiFi 7 models added with 3006_102.5_alpha1-gef34cb8940 (GT-BE98 Pro, RT-BE86U, RT-BE88U, RT-BE96U):
3006.102.5 (xx-xxx-2025)
  - NOTE: For developers, please note that the new default branch
          is now called "main" - it's what was previously the
          3006.102 branch.
          The "master" branch has been renamed "master-old", and
          is no longer actively used.  Due to how the 3006.102
          branch diverged, it was easier to do it this way than
          to fold back 3006.102 on top of master.
  - UPDATED: Merged GPL 3006.102_37957 for Wifi 6 devices.
  - UPDATED: Merged GPL 3006.102_38757 for WIfi 7 devices
             (except RT-BE92U).
  - UPDATED: dropbear to 2025.88.
  - CHANGED: Reworked System Log -> Connections page.  You can
             now filter the list, local hostnames are resolved,
             automatically refresh the page, and IPv6 is supported.
  - CHANGED: Replaced netstat-nat by a fork called netstat-nat-ng.
             This fork fixes a number of issues with IPv6 and
             field size.
  - CHANGED: Updated Control-D DoT server entries (dave14305).
  - FIXED: OpenVPN server set to "Internet only" would fail to
           block LAN access (invalid firewall rule from SDN was
           bypassing it).
Same download page.
Has the issue been fixed already where if you set and SAVE the SDN (VLAN) Profile from VLAN Switch Control Settings, the will go back to the first entry in the SDN (VLAN) Profile drop down list regardless of the one you have selected?
I have this issue on 3006.102.4 on RT-BE96U
This is an alpha. Test it.
Router: BE88U
Browsers tested: Chrome and Safari
Problem: The Apply button is not working on wireless general, so I can't enable 160Mhz/Channel 12,13
Router: BE88U
Confirmed in Firefox (ubuntu)
All seems OK and working, no issues.
Except the (already fixed for next alpha) Aura RGB page (for me on Waterfox).
Small niggle. CPU temperature showing zero in System Info.
This is an alpha build. Just test it. why do you even have to ask? lolx
For an Alpha build this is outstanding. This is on the GT-BE98 PRO, the only problem I had is when I imported a config file from the 04 firmware, I could not establish an internet coinnection. I factory reset and then entered everything in from scratch and now it is working perfectly. I have MLO and 3 additional VLANs set up. All working perfectly and everything on the network is lightening fast.
Fantastic job Eric!
CC
Upgraded GT-BE98 Pro last night. Working well with the exception of the few minor glitches already mentioned. One very positive improvement is that devices seem to more readily and consistently show in Network Map and AiMesh tabs.
Upgraded my RT-BE96U to alpha1, it looks good so far. Now testing the new WiFi drivers from Jun 24, version 17.10.369.39012
Any idea of a timeframe for the RT-BE92U version? Thank you for your work!
No. The GPL they uploaded yesterday was truncated (major routing issues between Taiwan and Canada these past few weeks, exchanging files has been a nightmare), so whenever the engineer in charge of this gets back into the office, and successfully reuploads it.
