Useless smart connect.Where are these options at?
Which category? In wireless?Useless smart connect.
Is the public IP supposed to have changed?
I had to wait until vpn provider change ip nummer.Is the public IP supposed to have changed?
You can't. There's no changelog with these code drops.Where would I find a more detailed changelog to what 37957 brings to the table?
There's no spinning wheel because the page does not get reloaded, and it only takes 2-3 seconds at most. An Ajax call is sent to the web server, and the response is retrieved, and updated on the existing page.I had to wait until vpn provider change ip nummer.
I thought the spinning wheel would spin when I pressed refresh, but it didn't.
Seems to working without spinning wheel.
www.snbforums.com
TLS Hostname: p1.freedns.controld.com
IP Addresses:
76.76.2.11
76.76.10.11
2606:1a40::11
2606:1a40:1::11
"dnspriv_label" : "Control D 1 (Network Security)",
"dnspriv_server" : "2606:1a40::11",
"dnspriv_server" : "76.76.2.11",
"dnspriv_port" : "",
"dnspriv_hostname" : "p1.freedns.controld.com",
"dnspriv_spkipin" : ""
"dnspriv_label" : "Control D 2 (Network Security)",
"dnspriv_server" : "2606:1a40:1::11",
"dnspriv_server" : "76.76.10.11",
I’ve sent an update for review. Are you using the new settings manually? Any issues?Thanks in advance for your attention.
Thanks, Dave, for submitting the update. I've recently switched to Quad9, but yes, I was manually using the settings from my previous message without any issues.I’ve sent an update for review. Are you using the new settings manually? Any issues?
I read their docs on how to configure stubby on Linux for the desired configuration.In order to double-check the IPv4 and IPv6 addresses for the 3 profiles you've submitted (Malware, Ads & Tracking, Family Friendly), I've just sent an email message to Control D.
Excellent, thanks for sharing the link!I read their docs on how to configure stubby on Linux for the desired configuration.
We use essential cookies to make this site work, and optional cookies to enhance your experience.
