IPv6 Firewall
TizzPutt
Hello,
Running 378.55 on AC68 router.
I've had some trouble configuring the IPv6 firewall. When I enter in a service name and all the other fields, and hit the add button, it shows up as an entry, but when I apply, the entry disappears.
I also confirm that ip6tables -L doesn't show the entry.
Is this a known issue? Anything I can do to work around it? I'm not very comfortable with ip6tables, but I want to enable a TCP and UDP port to an IPv6 device inside my network (which is DS-Lite, so public IPv6 and private uncontrolled NAT'ed IPv4).
When the firewall is off, I can reach the device fine.
Thanks,
