IPv6 lease time
mach6
I'm running 384.13 on AC3100
  • I didn't find location to configure the dhcp lease time for ipv6 on the web interface.
  • In /etc/dnsmasq.conf I found dhcp-range=lan,::,constructor:br0,ra-stateless,64,600 The lease time is only 600s. On both linux and windows machine, I found ipv6 become unavailable after 600s. I have to restart the network on client side. But it will then only work for 600 s.
  • I dig into the code and found in file release/src/router/rc/services.c, line 1573 (https://github.com/RMerl/asuswrt-me...39b49a/release/src/router/rc/services.c#L1573) the lifetime is hard-written as ra_lifetime = 600 for stateless ipv6. According to the manual of dnsmasq, http://www.thekelleys.org.uk/dnsmasq/docs/dnsmasq-man.html, the time here should be lease time.
  • In addition, for ra advertisement, shouldn't there exist a program called radvd? I didn't find the executable in /usr/sbin/radvd as well as the configuration file /etc/radvd.conf
Is this a bug or something configured incorrectly?
I don't use IPv6, (so could be wrong!) but I believe radvd server functionality is achieved using dnsmasq+odhcp6c
e.g. I just hacked 'dnsmasq.conf.add' with the sample IPv6/ra directives from the dnsmasq man page, restarted dnsmasq, and manually started odhcp6c daemon
e.g. Syslog
RT-AC86U dnsmasq-dhcp[31349]: DHCPv6, IP range 1234::2 -- 1234::500, lease time 12h
RT-AC86U dnsmasq-dhcp[31349]: router advertisement on 1234::
RT-AC86U dnsmasq-dhcp[31349]: IPv6 router advertisement enabled
RT-AC86U odhcp6c[31452]: (re)starting transaction on br0
RT-AC86U odhcp6c[31452]: Starting SOLICIT transaction (timeout 4294967295s, max rc 0)
So it would appear that I have configured 'IPv6 router advertisement' with DHCPv6 leases of 12 hours?
e.g. Syslog
Very interesting!! Could you pelase share the line you add for DHCPv6? With the default settings, I restarted dnsmasq but only got
Nov 15 23:20:58 dnsmasq-dhcp[32120]: DHCP, IP range 192.168.1.150 -- 192.168.1.254, lease time 1d
Nov 15 23:20:58 dnsmasq-dhcp[32120]: DHCPv6 stateless on br0
Nov 15 23:20:58 dnsmasq-dhcp[32120]: router advertisement on br0
Nov 15 23:20:58 dnsmasq-dhcp[32120]: DHCPv6 stateless on 2001:470:895b::, constructed for br0
Nov 15 23:20:58 dnsmasq-dhcp[32120]: router advertisement on 2001:470:895b::, constructed for br0
Nov 15 23:20:58 dnsmasq-dhcp[32120]: IPv6 router advertisement enabled
The log doesn't show anything related to the lease time of DHCPv6. Although there does exist binary odhcp6c, it also doesn't start automatically.
FYI, I'm using Hurricane Electric IPv6 Tunnel . I'm not sure if it is because of this. My current solution is to add a file /jffs/scripts/dnsmasq.postconf like the following to enforce infinite lease time
#!/bin/sh
CONFIG=$1
sed -i 's/^\(.*ra-stateless.*\),[0-9]\+$/\1,infinite/' $CONFIG
Probably due to the latest dnsmasq version on my RT-AC86U running v384.14Beta1
RT-AC86U dnsmasq[19055]: started, version 2.80-93-g6ebdc95 cachesize 1500
This is a little off topic from lease timing but some what related to IPV6 leasing. What would you recommend as an option for Dnsmasq.postconf if you were wanting to tell it to not do leasing but to still allow passthru, I am interested in trying out a different source for DHCP and the asus router is horrible when it comes to trying disable dhcpv6 leasing when you want to use a different DHCP server for your devices.
