Is it possible to enter multiple sites to be blocked in one shot?
Phoenix
I entered a few ad servers in my Nighthawk X10's blocked sites list like the MSN Ad servers but can I add many sites in one shot to be blocked rather than having to enter them one at a time?
I would like to add the entire list that is in the MVPS hosts file to be blocked through my router
  1. Install the telnet program on your computer.
    For Windows 10, do like this:
    Hold down the Windows Key, then press the “R“ key.
    The Run dialog box appears. In the Open: window, type:
    pkgmgr /iu:”TelnetClient”
    Click OK.
  2. Enable Telnet access to the router:
    Login to the router page, http://routerlogin.net/debug.htm
    Check the box for: Enable Telnet
  3. Login to the router:
    Open a command prompt (Windows 10):
    cmd
    Click OK.
    In the opened DOS-command window, type:
    telnet routerlogin.net
    (The password is the same as from the normal router login page http://routerlogin.net)
  4. Now you can run the commands you want
I am using the Nighthawk X10 on the latest 1.0.4.12 firmware
I took a look at your guide but where do I paste that command? there are 2 command sets as well I'm confused
    Click OK.
    cmd
    Click OK.
Thanks for the detailed instructions man.
I got to the point where I wanted to copy/paste the command(s) but this is what I get:
What am I doing wrong?
Good screenshot, thank you!
(The -a for unzip is not needed)
Please install Voxel Firmware as per my posting above.
No settings are lost and configuration backup is the same.
Then try again.
Then try again.
I installed the latest Voxel Firmware but I think there's an issue in the commands bro. This time the MVPS hosts file downloaded fine and I did unzip it, then look at the errors in the following commands:
I think this is my problem,
After I enter the 2nd installation command, see the error message that it throws:
/bin/opkg install dnscrypt-proxy-2_2.0.16-1_ipq806x.ipk
You should use dnscrypt-proxy 2 for R9000. Above is for R7800. And you tried to install R7800 version to R9000. I.e. p.3-p.4 are changed to:
cd /tmp
wget --no-check-certificate https://www.voxel-firmware.com/Downloads/Voxel/R9000-Voxel-firmware/DNSCrypt-Proxy-2/dnscrypt-proxy-2_2.0.16-1_r9000.ipk
/bin/opkg install dnscrypt-proxy-2_2.0.16-1_r9000.ipk
The rest is the same as for R7800 (from p. 5).
P.S.
This is not needed for R9000:
/bin/opkg install ca-certificates_20180409_all.ipk
(such package is already included into R9000 fw).
Voxel.
cd /tmp
P.S.
Voxel.
Perfect! Got it done perfectly now!!
Also huge shout out to kamoj for your help and patience with me. Cheers
