Is it possible to search/find filename via ssh?
If the OS doesn't have locate or whereis
I've often used
 alias locate="du -ah / 2>&1 | grep "
locate myfile
when I'm looking for a file with a known extension I can use locate "my\.file" to look for my.file
This works extremeley well for me when in a small file system such as in router firmware or a PiBox .
Your Mileage May Vary
You can also use the "find" command on most linux platforms, including most (all?) Asus routers. :)
"find --help" will show you the syntax required
im trynig to find the file ca.crt thats located in http://192.168.2.4/ca.crt
but i just cant seem to download it
i have to fin it and opy it somewhere so i can download it
All these live in /opt/var/cache/pixelserv.
Plus, that link will download it too.
Ok, I went to /opt/var/cache/pixelserv. downloda ca.cert
ran it on my PC
but still neither 19281.68.2.1 nor router.asus.com is secured...
what am i diong wrong?
umm
Here are some sreenshots that shows ive installed the ert on the PC and on chrome:
but stil router.asus.com wont go HTTPS (Non0Secure)
umm
It should be secure if you browse to the name in the cert... https://router.asus.com/
Pixelserv generated certs aren't as flexible to include IPs in the Subject Alternate Name field. The router's own /usr/sbin/gencert.sh can do that, but it's self-signed.
Nope,
don't happen, httos://router.asus.com loads a blank page now, http://router.asus.com loads but no-secure....
npt really sure whats wrong....
id appreciate your help
On PC's I simply use the Windows 10 File Explorer\Network to get files off the router:
I used the same and got the file...insalled it;....but still not secure
question:
do you have http:///192.168.1.1 as HTTP (secured?) so doe https:router.asus.com ?
I had the same problem. It could be that the certificate is rejected because it's valid for 10 years. A certificate can't be valid for more than 39 months to be validated by your browser. I solved it by following the original instructions for pixelserv certificates which creates a certificate with the shorter validity. Here is the command to create it from the pixelserv website:
Install certificates for Router WebGUI to JFFS (needs to be renewed after JFFS format):
sh -c "$(wget -qO - https://kazoo.ga/pixelserv-tls/config-webgui.sh)"
Follow the instructions and install the new certificate on your browser. I also use the same certificate for the router UI by loading it in the DDNS section of the router:
WinSCP. Enable on SSH on the router. You should be able to log in and browse in the GUI.
Can you scrrentsjot me pocs of https 192.168.x.x
